Old 04-17-2015, 09:46 PM
Monkeyman2500 Monkeyman2500 is offline
Default 50c deck help
I've got the old 1650 I bought running pretty good. Today while mowing the deck went kaput on me. The middle pulley that drives off the belt is no longer attached to the shaft its on. It just spins and wobbles around. So is this repairable or do I need to buy a new part? Thanks.
Old 04-17-2015, 09:51 PM
CubDieselFan's Avatar
Yep, you can still get those new or if your a good welder, you can fix it. I am not a welder so I would buy a new one.
Old 04-17-2015, 10:42 PM
machinehead323 machinehead323 is offline
without better descriptions or a pic, it could be as simple as a woodruff key sheered. that is what keys the shaft and pulley together
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 04-18-2015, 12:15 AM
Ok, this helps. I will check it tomorrow. I don't have a socket big enough for the nut on top so I will have to get one.
Old 04-18-2015, 12:58 AM
Ok so after looking at parts online under 50c deck, they say the nut on top of the pulley is 3/4-16. The nut on mine is over 1". So are the other pulley nuts and also the nuts on bottom of blade. Does this sound right?
Old 04-18-2015, 09:16 AM
Sam Mac Sam Mac is online now
3/4-16 is the thread size. Most of those nuts take a 1-1/8" socket. I use a 1/2" impact wrench to get them off.
Old 04-18-2015, 10:31 AM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Where are you located in TN?
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 04-18-2015, 01:23 PM
Right between Gainsboro and Livingston.
Old 04-18-2015, 01:55 PM
RR1862CC's Avatar
If you were closer you could bring it by and I could zip it off for you. You will need a way of blocking the shaft from turning. If the blade is still on the bottom just put a wooden block between the block and deck shell then take the nut off. you will probally need a long handle on the socket to turn that nut off.
Allis Chalmers 416
Brinly 10"plow
Old 04-18-2015, 09:25 PM
Thanks for the offer. I'll pick up the pulley and socket next week and hope I'll be back in business soon.
