Old 04-19-2015, 08:25 AM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Default What is this bracket for?
What is the white bracket on the foot rest for?
Old 04-19-2015, 08:30 AM
c69ss396 c69ss396 is offline
it holds the rod that tuns the snow thrower head...
That is for the chute control for the snow blower. Click on this link and you'll see a pic of it.
http://ccmanuals.info/pdf/QA%2036%20...tors%20Man.pdf
Old 04-19-2015, 08:36 AM
Thanks for the fast reply!
Old 04-19-2015, 03:02 PM
That safety switch bypass is an accident waiting to happen with your driveshaft!! If that was my tractor, I would either fix the safety switch properly or secure that bypass more than tightly fitting it in a jam like that and without a driveshaft (clutch) cover.
Old 04-19-2015, 03:40 PM
Thanks, I was wondering what that wiring was for. Looks like McGiver was working on it... Is that wired to the clutch pedal switch?
I saw one of those guards on ebay this morning. I'll go back and give it a look.
Old 04-19-2015, 04:05 PM
Yes, it is for the safety switch.
Old 04-19-2015, 05:39 PM
gdheck's Avatar
gdheck gdheck is offline
See if the old switch is still there and if it will work (probably won't). If not a new one is 40 bucks well spent. I don't like all the other safety switches the later ones have, but I always replace the neutral safety in case a kid happens to wander into the yard and mess with it while I'm not around. I also take the key when I shut anything off unless I'm right there working on it.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 04-19-2015, 06:45 PM
Thanks guys.
