Old 04-18-2015, 11:33 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Cub Cadet wanted a 15 hp tractor. kohler didn't make a 15 hp engine so they slapped 15 hp decals on what they had
Old 04-21-2015, 09:10 PM
Justin Witt Justin Witt is offline
The engines are the same. Just like a k301 is the same as a k341 (12 hp and 16hp) only difference is the carb. I know an older guy that worked for Kohler, Briggs, and Tecumseh back in the day. And he told me all about this. All though I don't think Kohler has ever made a 15. Probably a 14 or 16 hp carb on a 18 hp engine.
Old 04-21-2015, 09:44 PM
close but no cigar,
Model: .................................................. ................................. K241 ................. K301 ................ K321 ................... K341
Bore: ................................................. inches (millimeters) ... 3.25 (82.6) ...... .3.38 (85.7) ....... 3.50 (88.9). ........ .3.75 (95.3)
Stroke- ................................................ inches (millimeters) ... 2.88 (73.0) ...... .3.25 (82.6) ....... 3.25 (82.6). ........ .3.25 (82.6)
Displacement: .............. cubic inches (cubic centimeters) ... 23.9 (391) ....... .29.1 (476) ........ 31.3 (512). ......... .35.9 (588)
Power (@3600 RPM): ................. horsepower (kilowatts). .. IO (7.5) ............ 12 (9.0) ............ 14 (10.4). ............ 16 (11.9)
Approx. Weight: ...................................... Ibs. (kilograms) ... 118 (53.5) ......... 118 (53.5) ........ 118 (53.5) ........... 122 (55.4)
Old 04-22-2015, 12:41 AM
You better learn to read a book instead of listen to "some people". Check George's post above. The different models of the K series are all different CI's. The numbers tell you this. K301 is 30 cubes, the K321 is 32 cubes.
