Old 04-06-2015, 07:13 AM
782Smoker 782Smoker is offline
Default 50C rebuild
I am rebuilding the deck off my 782D and was wondering if anyone has put a smaller pulley on the center spindle to speed up the tip speed? Do I need to replace both the pulleys or can I get the top one off by itself? I have seen this done on the 44 inch decks but not with the 5/8" belt. Any help is much appreciated!
Old 04-06-2015, 08:34 AM
I am unaware of a "speedup pulley" for the 50C mower deck. I am also quite sure, the center pulley is considered a double pulley (one stacked on top of the other) and is an assembly.
IF.........one wanted to get more "tip speed", it would require custom engineering and fabrication.
Old 04-08-2015, 07:31 PM
i did this to my 50" deck....it does have a stack pulley..i cut the old one off, bought a wdldable 4.5" pulley, turned the center out on a lathe until it was the same as the cylinder(spacer) and then fried it together...works great...i can take some pics if you want them...definitely get better blade speed...
Old 04-18-2015, 08:51 PM
If you could get pictures for me, that would be great!
Old 04-18-2015, 09:40 PM
sure...the deck is hanging on the wall right now, but ill get it down and pop the cover off...do you have an extra stack pulley laying around??
Old 04-19-2015, 10:41 AM
ccpullin ccpullin is offline
Back in the IH days they made a speed up pulley for the 44 & 50 decks. It was for the narrower 3V belts and took care of the cutting issues this deck had leaving swirl marks when turning. The only issue was that they did not make a shorter belt and it was at the end of adjustment when new. I had to purchase an aftermarket belt, but worked fine. I am not aware of a "speed up" pulley for the later "B" section 5/8" belt as used on the 50C. I had issues with a Haban 60" on a 2082 not mowing well so I went to a larger pulley on the engine clutch to solve the issue. I had to rivet a larger pulley from a later model on the clutch shoe and install a longer belt. If you go too small of pulley on the mower it will burn belts due to the lack of surface gripping area and it is hard to wrap a large belt around a small pulley and keep it tight. You are better off installing a larger pulley on the engine clutch.
Old 04-20-2015, 08:41 AM
I actually do, my dad has a 50C that he had under his diesel. That shell is pretty much rotten so I access to whatever I may need. Where did you find the pulley, and what size did you go with?
Old 04-22-2015, 07:41 AM
i got the weld "a" pulley at the case ih dealer down the street.. i think its a 4" or may be a 4.5" but i think its a 4" i will check when i get it down... i would think that any farm and barn store would carry them...i used a hole saw to cut the original stack pulley apart..from the top...it was just bigger than the "spacer" in between the 2 pulleys... does that make sense??
Old 04-22-2015, 08:27 AM
That makes sense! I think I am going to run a 4.5 inch pulley just for the safety and longevity of the bearings. I hate to have to put bearings in every few years.
Old 04-22-2015, 09:33 AM
The bearings of the taper roller style don't wear out so much from speed or the lack of it, but more from
lack of lube/power washing/string/wire wound around the lower spindle cutting out the seals.
When replacing a seal I find it is advisable to install the upper seal with lip facing out/up so when greasing them with a grease gun, you don't force the seal out of it's housing, ruining them.
The grease will just expel around the upper seal.
