Old 04-24-2015, 10:29 PM
Group_44's Avatar
Group_44 Group_44 is offline
Default The Fun Begins
Has anyone successfully tapped the connection ports on a Cyclops implement control valve to accept an NPT fitting? I am pulling the engine in my 2086 shortly to replace the plastic cam gear and while its out I plan to add a second valve and lines for front outlets. The factory kit lines are NLS and because it doesn't look like anybody makes an adaptor to go in the existing clamp style ports, tapping looks to be the best way to go. I know I'll have to disassemble the valve but the hole look to be pretty shallow and I am not sure how many good threads it will hold. It looks like an 1/8" NPT tap will work, is that big enough? Looking for some advice from the experts. The other option I understand is to cut the ends off a couple of used lift lines and have a new hose of the correct length crimped on.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 04-24-2015, 10:31 PM
Group_44's Avatar
Sorry for the double post, How do I remove it?
1641 w/48" Deck
Old 04-24-2015, 10:39 PM
click on your post, click on edit, select delete, check delete message near the bottom, click delete this message lower right
should work
Old 04-24-2015, 10:52 PM
Group_44's Avatar
The delete option doesn't appear on the second thread only this one. Guess I have to wait for a moderator.
1641 w/48" Deck
Old 04-24-2015, 11:14 PM
ok
beyond my abilities, they will be along and fix it, no worries
Old 04-25-2015, 02:47 AM
Do not tap it, you will ruin the valve block.
Contact moderator Sam Mac, he has the parts in which you seek.
He'll probably be on in the AM.
Old 04-25-2015, 07:23 AM
I only have the adapter that goes between the valves to allow you to stack them.
Old 04-25-2015, 08:14 AM
Group_44's Avatar
I already have a adapter that goes between the two valves, I need to run the lines to the front outlets and the feed line on the top. There was a suggestion in another thread to tap the valve. Sam, do you still have any of those adapters left, I need one for another tractor?
1641 w/48" Deck
Old 04-25-2015, 08:48 AM
I still have 3 adapters. As far as tapping the valve body, I'm pretty sure it can be done but I don't have one to try it on. The valve would need to be dissembled. If NPT wont work maybe straight threads with an O-ring. Something like this.
http://www.surpluscenter.com/Hydraul...9-6801-4-4.axd
Old 04-25-2015, 09:07 AM
Datsun1973 Datsun1973 is offline
Talking
You could use the ends from a set of lines and flare the other side to accept a tube nut effectively making your own lines or adapter to standard stuff. Being a race car guy I am sure you have the 45 flare tool and a box of AN fittings. Hehe
