Old 04-26-2015, 08:21 PM
That is good to know...
Up to 534 and counting...
Ok guys settle down.
Trust me, it's after 5:00 PM so I can't get much more settled, almost bed time for me.
Old 04-27-2015, 03:55 PM
Ok guys I got the wiring figured out but I don't have any spark, I did yesterday, I tried sanding the points, I already sanded the magneto too.
Old 04-27-2015, 06:06 PM
Got spark back, the points were out of adjustment.
Old 04-27-2015, 06:29 PM
sbauerz28's Avatar
What style ignition does this have? Are the points under a cover under the flywheel with one wire running to a Magneto next to the flywheel? If it is, the first thing that comes to mind for it kicking back would be a sheared flywheel key. That would throw the timing off.
Old 04-27-2015, 06:35 PM
It has a points cover on the side of the engine With the condenser inside, and a magneto behind the flywheel, I already had it all apart, I don't think it even has a flywheel key.
Old 04-27-2015, 06:44 PM
sbauerz28's Avatar
A stator behind the flywheel?? Maybe I'm confused. Does it have a coil just like a kohler then?
Old 04-27-2015, 07:00 PM
No coil, I posted a pic of it in my today's haul thread.
Nick
Maybe it would be a good idea to check out a Simplicity forum for this issue.
https://www.google.com/#q=simplicity+tractor+forums
Old 04-27-2015, 07:01 PM
Nick
Ok I will, thanks Sam.
