Old 05-01-2015, 07:38 PM
BandMan BandMan is offline
Default Transmission Release
I'm looking for the transmission release on an 1810. I need to push it, won't start.
Old 05-01-2015, 08:03 PM
First, welcome to OCC...........
The 1810 has "automatic" Hydro Release Valve. You might push it slightly backwards, then forward to move the tractor.
Old 05-01-2015, 08:08 PM
Thank You! Where will I find this valve?
Old 05-01-2015, 08:16 PM
the valves are automatic so theres no lever or button to push, what Roland meant is to push the tractor backwards so they release and then you can push the tractor forwards.
You won't find them, they are built into the valves. As Roland said just go and push just keep the speed and distance low and slow.
Old 05-01-2015, 08:22 PM
Thank you very much! Your responses were quick, to the point & helpful! We bought this mower used years ago & it is great. The speed creep is annoying, but I cannot remember many problems. The starter spins but will not spin the motor. Thanks again!
