picked up this 2082 plastic a little ratty but kinda useable rear end still tightly mounted with a 50 inch deck for 100 but flywheel let loose of the magnets what other models will the flywheel work off of?
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
You can get new magnets and fix that one.
actually the magnets are pretty much intact but where can i get the magnets J?
I purchased some rare earth magnets from Epay and replaced 2 of mine that were missing. They worked the same as the ones that were missing. I went this way because I am cheap.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
had a 18 out of a 1864 i threw into it to see what shape rest of tractor is in. hydro seems quiet and all seems to work ok unsure what im going to do with it. the mag 20s magnets are all there minus some corners and edges i think i will try to glue them back in and get it running
Just make sure the poles are N-S-N-S. Here is a link with some useful info.
http://www.lawnsite.com/showthread.php?t=398206
In the linked article the author used JB Weld to secure the magnets. Is there a better product to glue the magnets in the flywheel with? Not knocking JB Weld just want the strongest repair.
I have one I want to repair for a spare.
Cub Cadet 1811 undergoing restoration Cub Cadet 1862 waiting for paint Cub Cadet 1050 finally got all the parts bought so next in line behind the 1811 for restoration Allis Chalmers 416 Massey Ferguson MF-8 Brinly 10"plow Soil Mover garden tractor dirt scraper Taking donations for a new bigger garage to hold them all
JB weld is fine. I would use a two-part epoxy of some kind. JB weld is really more of a filler than a bonding agent.
I did use an epoxy to bond the side fairings to their mounting brackets on otr trucks. I bet if those did not blow off that same epoxy would work well on the magnets.
Remember too that centrifugal force keeps the magnets in place, the epoxy keeps them from "walking".
