Tonight I sand-blasted (using coal slag) the last piece of my 1650, which happened to be the 42" mower deck. It has some several small holes where it has rusted through, but hundreds of deep rust pits. I was thinking about using my welder to build the metal up and then use a side grinder to level it back out. But then I thought about a filler (like Bondo) would be easier. The next thought was J.B. Weld, since I have heard that it is very good at adhesion and actually contains steel. Has anyone tried using J.B. Weld as a filler for rust pitted parts?
Mike
1978 1250 - in pieces 1976 1650 - running and pulling |
Post some pictures of your deck.....
I don't know how it will work, but it won't be as nice to sand as bondo
A little thinner on a finger before it is cured will smooth that JB right out. You can also use a bondo spreader to apply. On cast, you cause rough sandpaper pressed into the JB, repair will be well hidden.
I used it on a rotted gas tank for a Kawasaki a few years ago. Worked very well and it did sand nice.
JBweld should work just fine for deck repair where there is no structural strength required. I just finished repairing the 42" cast end deck on my 122 by welding up the holes in the sheet metal. I found a place that I had repaired with body filler many years ago, still in place and doing the job.
122 original, well used. Owned since 1972 2182 new to me. Refurbished and gave to my son. Deere 4300 4WDA HST with FEL Many old Ford tractors, all gone now Couple old Ford trucks |
You might consider a product like All-Metal. It's a body filler that has a metal power base, works up like Bondo, sticks like crazy and doesn't absorb moisture like ordinary body filler. I used it when I restored my Jag 15 years ago and it still looks good. It is a little harder to sand because of the metal content but not impossible. The finished appearance is very similar to JB weld.
2082 w/60" Haban Deck & 450 Blower,AGs,weights 2084 w/54" Deck & 451 Blower 2086 w/54" Deck, 54" Haban Snow Blade 1864 w/54" Deck and weights 1641 w/48" Deck 1650 w/44" Deck parts Tractor (getting smaller all the time) 445 John Deere w/ model 40 FEL (went over to the dark side) |
I used a fiber glass body repair kit like for fiber glass car bodies on my 44a deck to repair the holes. Worked fine. I've also used the jb weld putty in a tube that you knead together to repair a broken tab on the headlight on my 1211. Holding us from me I guess time will tell.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
