Old 05-18-2015, 11:42 AM
jimbob200521's Avatar
Remove the bolts on each side under the rubber foot rest pads OR the two bolts on the back of the foot rest pads holding them to the fenders. Then, while sliding the seat both all the forward and then all the way backwards, remove the 4 allen head bolts holding the seat on (two up front and two in the back, both tucked away in the seat slide rails). Lift up the seat carefully, disconnect the two wiring harness connections under the seat, and remove the seat. The fender pan should then be free.
-Ryan
