Old 05-20-2015, 10:22 PM
dodge dodge is offline
Default HELP 1641 hydro gear pump quit
tractor wont move. but hydro deck goes up and down.just makes a loud hydraulic whining sound. need a pump I think.cant find a new one. I would like to find a used one if I can. or someone to rebuild it.
Old 05-21-2015, 08:47 AM
Is the oil full? Did you change it recently? What about the filter? Is the release valve pulled up?
Old 05-21-2015, 06:22 PM
efharg's Avatar
efharg efharg is offline
I'm parting out an 1863. I think it probably uses the same hydro pump as the 1641, but I'm not for sure. If you can use it, PM me and maybe I can help you out.
882
Old 05-21-2015, 06:39 PM
Should be the same looking at Parts Tree.
Old 05-21-2015, 07:15 PM
look at parts 20, 21 and 22 on the Parts Tree blowup of the hydro. That is the relief valve that the knob on the trans cover pulls against. I just scrapped out a 1641 tractor that wouldn't pull itself. That valve looked like it was depressed and wouldn't come back up. This was after the tractor was picked up my a fork lift.
I don't know why I can't post the image but it doesn't work and I'm out of time.
May not apply here but worth a look.
Old 05-21-2015, 07:16 PM
And now I see this.....................
http://www.onlycubcadets.net/forum/s...960#post329960
Old 05-22-2015, 04:38 PM
efharg's Avatar
Here is what I have. It is a ported pump for use with hydraulic deck lift so It should work.
882
