Old 05-22-2015, 01:48 AM
ssechrist ssechrist is offline
Default Mowing
Finally got my 60 inch Haban deck up in shape to mow. I've been trying to do some mowing in the breaks in the rain (floods) we've been getting so I haven't got mow much.
I'm having problems with the deck leaving strips between the blades, seems like it is little on the right side but it happens on both sides. I put new blades on the deck, the belts are all pretty new & everything is working good except for the strips its leaving. I bought the blades that the deck called for but it seems to me that the blades need to be about a half inch longer as they don't look like they meet close enough together. Anyone else ever have this problem?
Old 05-22-2015, 03:53 AM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default Haban
This may just be your deck timing (blade alignment). Not real sure but you should try setting two outside blades straight across and the center straight up and down. And of course, make sure all are turning and you don't have a belt slipping.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 05-22-2015, 08:25 AM
You don't time a 60" Haban. Blades should be 21" long.
This is from the Oregon catalog
21" long 1/2" center hole 2" wide 1/4" thick
759-3411 Cub #
759-3839 Cub #
91-442 Oregon #
Probably not your problem but I bought a Haban once that the owner said it didn't cut very well, it had one blade on upside down.
They also don't like wet grass, check for buildup.
Old 05-22-2015, 08:31 AM
759-3411 Cub #
759-3839 Cub #
91-442 Oregon #
Those are the blades I have. Why does it leave strips? Speed doesn't seem to change it, I can slow down to a crawl & it will still leave the strips>
Old 05-22-2015, 08:49 AM
OldCubby OldCubby is offline
759-3411 Cub #
759-3839 Cub #
91-442 Oregon #
Is it my eyes or did you install those blades upside down?
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 05-22-2015, 09:51 AM
The guy I bought that deck from had 1 blade on upside down. He said he didn't like the deck because it didn't cut very well. Seriously, I wonder why. Pulled the blades, sharpened them and put them back on the way they are supposed to go and it cuts like a champ.
Old 05-22-2015, 09:53 AM
If you can post some pics of the underside we may be able to see something that your missing.
Old 05-22-2015, 10:50 PM
gdheck's Avatar
gdheck gdheck is offline
My 60 started leaving strips the other day so I stopped mowing. Good thing I did, because 2 of the blades had worked loose. Never had that one happen before.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 05-23-2015, 08:00 AM
raytasch raytasch is offline
Are we talking thin strips like where there would be no blade overlap or just areas where all the grass does not get cut but some of it knocked down?
122 original, well used. Owned since 1972
2182 new to me. Refurbished and gave to my son.
Deere 4300 4WDA HST with FEL
Many old Ford tractors, all gone now
Couple old Ford trucks
Old 06-13-2015, 12:33 PM
V30crewcab V30crewcab is offline
my haban doesn't mow good either. leaves all kinds of grass unless you barely creep along. never have figured it out. its like the blades dont spin fast enough or something. my little green sabre does twice as good a job.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
