Old 05-25-2015, 11:14 PM
darryljs's Avatar
darryljs darryljs is offline
Originally Posted by darryljs View Post
This one is supposed to work for a 1 to 10 cylinder, it's 2 1/16" and $56.99 with free shipping.
Attachment 64704
I ordered this one to see if it works on our cubs. http://www.ebay.com/itm/291162356660...%3AMEBIDX%3AIT
Originally Posted by OldCubby View Post
It looks promising....I wish they had one like that down to 4,000rpm. Let me know how it works for you.
I finally got to hook this up and it works good. Checked it against an optical tach and they read the same.
Hooked the green signal wire to the - side of the coil and set the tach to one cylinder. I also have two other tachs to play with as soon as I have time.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 05-28-2015, 03:13 PM
OldSkull's Avatar
OldSkull OldSkull is offline
I finally got some spare time today to mod the Farat RPM, He work very well! All I need to do now is adjust the 1650 carburetor for a lower idle, as soon I finish all adjustments and fitting in the dash, I post a video were you can see the timing light rpm beside the Farat and compare.
Now I need one of those 4000 rpm unit to play with
Gilles.
1963 100 (red)/in storage
Old 05-28-2015, 08:02 PM
bschmittling bschmittling is offline
http://www.egauges.com/8K-RPM-Tach-2-1-16-p/333-968.htm
This will also work.
Old 09-04-2016, 06:41 PM
twoton twoton is offline
Hey Gilles, wondering if you have any follow up on this for us...
Old 01-09-2017, 04:34 AM
guido guido is offline
Default hall effect?
Just thinking... this is what happens when you're an insomniac.
Has anyone tried a hall effect sensor to trigger an analog tach? The magnets could easily be embedded into the drive hub or clutch plate.
Someone smarter than me could figure out how many magnets it would need.
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
Old 01-09-2017, 10:28 AM
This video may help ZZZZZZZ......
https://www.youtube.com/watch?v=2fjcJp_Nwvk
Up to 534 and counting...
Old 01-09-2017, 12:13 PM
WTF did I just watch?
Old 01-09-2017, 03:43 PM
gardenpest's Avatar
gardenpest gardenpest is offline
thanks a lot for making me realize how uneducated I am ......
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
Old 01-09-2017, 04:01 PM
mortten mortten is offline
Can anyone spell half the things he said? That schtick has been around awhile. There was also a Chrysler Turbo Encabator.
Doug
QA-36A
42" blade
Old 01-09-2017, 04:22 PM
Although I do not remember my high school chemistry lessons but I do know enough about transmissions to have realized in the first few seconds that this video was complete nonsense. It would have been hilarious if youtubes AVE was the actor.
Still leaves the question. Hall Effect Sensors?
Alan
