Old 05-28-2015, 10:40 PM
swacor swacor is offline
Default Tiller
Hey guys,
My dad and I were looking into a rear tiller setup for either the 782, 1872 or maybe the 1864. We have a john deere tiller (4 foot) but it has the 540 shaft. Are there any options that would work. I saw there was a PTO kit for the 1872 but its not likely I would find one. I found a couple older IH built tillers for sale around me but not sure which ones work on what tractor. I do have the 3 point for the 1864 if that helps.
Old 05-29-2015, 05:47 AM
The correct Tiller for the 782 (or similar) tractor would be the IH 2B Tiller or the 190-400 (CCC) Tiller.
Old 05-29-2015, 09:40 AM
Berwil's Avatar
Berwil Berwil is offline
Even if you found a rear pto for the1872, it wouldn't work. Those pto's spin at 2000 rpm, much to fast for the 540 JD you have. Roland's suggestions are your best choices. The 2b will mount up to the 782 if you have a cat 0 3 point and is powered by the tractor. I am not positive, but I don't think it is compatible with an 1864. The 190-400 is self powered and can be put behind any tractor with a cat 0 3 point.
If your handy, you can mount up an older IH tiller on the 782 using a cub cadet 3 point hitch. It takes some work, but it's been done.
Bill
Old 05-29-2015, 12:31 PM
Bill
Or if you know a good fabricator , an adapter can be made to use it on a sleeve hitch adapter
Old 05-29-2015, 02:57 PM
How do those 190-400s work. There's one closer to me for sale but he wants 750.00 for it. It does look pretty nice though.
Old 05-30-2015, 12:31 AM
Berwil's Avatar
Luckily we all know one.
I love mine, on and off the tractor in minutes, and you don't get beat up like a walk behind. If you have a lot of garden, it will make short work of it which could make it worth that money. If you just want one, I would try to find one for less. FYI, MTD sold the same tiller branded as a White....even though they're painted all black.
Bill
