Closed Thread
Old 05-29-2015, 07:36 PM
BassBlaster BassBlaster is offline
Default Ever wanted to set your Cub on fire?
Better yet, put a stick of dynamite under it and watch it blow into thousands of pieces? Yeah, that's where Im at tonight with the 1864. Im so sick of working on a tractor every time I need to mow.
Okay, so as I mentioned in another thread, when I pulled the engine to clean it up, I replaced the head gaskets while it was out. Put the engine back in and went out and mowed with it for 20 minutes or so to put a heat cycle on the engine. It ran great! Better than ever. Fast forward to tonight and I pulled the tins and valve covers to re-torque the heads. Put it back together an now it wont start. When I turn the key, I hear the fuel shut off solenoid clicking and that's it. Nothing else. Nothing with the starter. I didn't touch anything electrical so nothing has changed since it last ran. I don't even know where to begin as electrical is most definitely a weakness for me. I do know all the safety features have been bypassed because the tractor will run or start regardless of the PTO, brake, seat, etc. Other than the seat, I don't even know where to begin checking these bypasses because I don't know where they are. Help please!!
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 05-29-2015, 07:49 PM
cubby102's Avatar
cubby102 cubby102 is offline
Start by checking your connections. Most likely a grounding problem...yes they can happen overnight seen it a few times. Make sure everything is clean and tight
Old 05-29-2015, 10:46 PM
neilh419 neilh419 is offline
When I pulled the tins on my 1641, the first time, I couldn't get it to do anything. I found a loose wire that wasn't in it's connection on the starter side on one of the metal below the head. Plugged it in, and was fine from there. Another time, it was the little solenoid by the battery. Tapped on it, and it started. That one took a little cleaning, and has been fine since.
Old 05-30-2015, 06:19 AM
yeeter yeeter is offline
No. No, I have not...
Old 05-30-2015, 06:49 AM
Me either. There hasn't been any issue(s) that can't be repaired.
Old 05-30-2015, 07:17 AM
Get a copy of the wiring diagram, a test light and a meter and start digging.
Old 05-30-2015, 08:31 AM
Right and this will get repaired as well. Im just really tired of spending all my evenings working on this stupid thing when all I want to do is mow the lawn and hang out with my family. I realize with a 20+ year old machine that problems are gonna pop up but this one has a new problem everytime I want to use it and its been like that since I brought it home. Just getting fed up.
I have a meter and a test light. Ill see if I can find a wiring diagram somewhere.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 05-30-2015, 08:47 AM
Send Roland a PM and I'm sure he can e-mail it to you
Old 05-30-2015, 08:55 AM
rwairforce rwairforce is offline
Yes it can get frustrating and I totally understand. I've had cars act the same way, they seem to fail only when I needed them and out came the tools again. It can be something simple but that doesn't help when you've already had a terrible day for a host of reasons and then you flop down on your Cub and nothing!
This is one fantastic reason that it's good to have more than one, especially when they're old. I have 8 Cubs with 4 ready to mow. This eliminates most concerns related to mowing and having a machine ready to jump on while buying me time to fix the one that won't work.
All 4 of my ready to mow Cubs cost less than one brand new one today so I feel pretty good about them.
Good luck and check those wires. I've even added a second ground wire just because of all the time I've heard people talk about the ground causing problems.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 05-30-2015, 09:21 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
No but I hauled the 1641 out of the garage where I didn't have to look at it for a while.
Cannon
Closed Thread
