Old 06-01-2015, 05:58 PM
unklechuckles19 unklechuckles19 is offline
Default 2082 Drive Belt Adjustment
Good evening fellas,
I'm back with a question about my 2082 with the 54" GT deck and I need another nudge in the right direction. Last time I mowed I ended up having to stop halfway through and do some work on the belt tensioner on the deck. It wouldn't hold tension on the deck belt, so I cleaned up the spring with some PB blaster and compressed air and it seemed to free everything up so I could get the yard done. While I had the deck out I did grease the tensioner. When I was putting everything back together I noticed the PTO drive belt was way out of adjustment as per the 324 deck manual I've got. I picked up a brand new belt from the local dealer and yesterday I installed the new belt and tried adjusting everything again, and I can't get it adjusted the way the manual wants.
If I adjust the adjustment arm in, so the pulley and belt ride lined up with the V notch in the frame (Right side as your looking from the front), the left side is way off (has the spring loaded arm with a notch to hold the pulley back). If I adjust the arm out, and pull the spring loaded side back in so the V notch on that side is positioned correctly, the adjustment arm side pulley rides way forward of it's V notch and almost touches the front of the frame. I've included a couple pictures as I'm sure you guys can't picture what I'm saying from my babbling.
Thanks for the nudge.
Right side adjusted
Left side adjusted
Old 06-01-2015, 06:24 PM
Post a pic of the mule drive, I want to see how you have it mounted. This is a Super with a Haban but it will give you an idea of what I need to see.
Old 06-01-2015, 07:23 PM
Do these two help you Sam??
Old 06-01-2015, 08:00 PM
Yep they sure do. Just my 2 cents but I would get a shorter belt. If you have a TSC near you take your old belt and match it up then get a couple shorter belts, keep the one that fits the best and return the others.
Thought maybe you had the sub frame mounted in the wrong holes but your good.
Old 06-01-2015, 08:06 PM
We do have a TSC locally, I'll give that a try. I wanted to throw some pics up here before I threw money at shorter belts. Thanks! Anyone else????
Old 06-01-2015, 09:01 PM
cub123's Avatar
cub123 cub123 is offline
Everything looks ok from here, just looks like the belt is too long. X2 for a shorter belt.
Old 06-02-2015, 06:36 AM
Any idea(s) on why the belt the factory calls for would be too long for the application?
Old 06-02-2015, 07:36 AM
What belt did you buy...????
Old 06-02-2015, 04:44 PM
954-3047 is what I got.
Old 06-02-2015, 05:08 PM
You got the part that it calls for. I'd still take your old belt to TSC and get a couple that are shorter than what you have. I just went through the same deal on one of my 2182's with a 60" Haban. I was basically Bush hogging with it, something that I know is wrong and picked up a branch that caused the PTO belt to jump off the deck pulley. Long story short it destroyed the belt so off to TSC we go pick up 3 different size belts and use the one that fits the best. The supposed Cub size and what I ended up using don't jive. BTDT.
