Old 06-23-2010, 08:09 AM
gcbailey's Avatar
gcbailey gcbailey is offline
Default Yet another 127 question.... sorry
Now that I have the rear end out, something just doesn't look right on my trunion/hydro linkage, I've been trying to compare stuff to cubfaq.com, but I don't know if those pics are from a WF/NF... Can someone tell me if these pics look like they have been "modified/fixed" in the past or what. What I'm talking about looks like a welded plate where the springs are. Of course, I probably don't know what it's supposed to look like. I'm also putting a video link to my youtube site....
http://www.youtube.com/gcbailey34#p/a/u/0/IB8b6VEqo38
Gary
Old 06-23-2010, 08:22 AM
TEET's Avatar
TEET TEET is offline
You are correct..Its been, "sort" of repaired in the past. It may work, but Its not really the proper repair for a worn trunion. Check out this http://www.onlycubcadets.net/forum/s...ead.php?t=4635 to give you a better idea of what it should look like. It may work ok as-is, but its possible that it could prematurely wear out other parts for the trunion. Interesting repair, I've seen lots of Cubs with trunion repairs, but thats a first for me
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 06-23-2010, 08:40 AM
gcbailey's Avatar
ya, when I got this 127 papaglide gave me the papers and a BUNCH of receipts. I don't know if he even knew about all of them. The thing about the receipts are, they are all from an IH dealer, but no descriptions.... back in '89 there is a receipt for $1,300..... so who knows what that was.
Gary
Old 06-23-2010, 09:45 AM
In the 4th pic, I see two low-grade bolts holding the hydro linkage bracket to the hydro unit. One of those bolts also holds the hydro to the transaxle. Those bolts need to be replaced with grade 5.
Old 06-23-2010, 03:10 PM
gcbailey's Avatar
Thank Matt....
Ya, there's a few places that I am seeing "newer" bolts, I think there are 2 on the rag joint also. Just another thing to add to the list.
Gary
Old 06-23-2010, 10:16 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
the one main bad thing about the repair/modification i see is that you will need to grind off the welds and remove that plate holding the 2 springs to replace them, with the original setup when you move the shifter it moves the plate but the springs allow it to have give so that it is a smooth acceleration, not jerky.
after that i see in the hydro slop vid that the lever for shifting is way to sloppy, should be nice and snug but move freely forwards and in reverse. if you want it to all work smoothly you will need to replace or shim the worn parts. hope it helps a little
Old 06-23-2010, 10:50 PM
ihnick's Avatar
ihnick ihnick is offline
is something wrong with the releave valves? they look different then the ones on my tractors. are those automatic ones?
Nick.
Old 06-23-2010, 11:14 PM
That might be a rare prototype, Its for sure one of a kind
Old 06-24-2010, 06:46 AM
gcbailey's Avatar
On the lever, I have found the ball joints are flat out worn. I've got a couple ordered. There is no friction at all in them.
Gary
Old 06-24-2010, 07:46 AM
Yes those are the newer automatic ones, the manual ones have a pin in the center as you are familar with.
