Old 06-03-2015, 07:44 AM
unklechuckles19 unklechuckles19 is offline
Unklechuckles, if you have the later machine then you have the 6" pto which takes a larger belt then the 4.6" smaller pto on the early machines. Can you measure that or shoot us a pic of it? Maybe someone changed it and put the wrong one on it. And you prolly should measure the deck center pulley also to see if it has been changed. The belt you picked up (954-3047) is a B section belt that is 95.3" long. Don't put a standard V-belt on it because all the twisting and turning will overheat it and destroy it quick. The TSC box store is your friend here. Go buy multiple belts, find what fits and take the rest back.
Thanks for the heads up on the belt, I'll grab a couple from TSC this weekend and see how I make out.
Front pulley on my machine measures right at 6", and the center deck pulley measures 5 5/8".
The PO of the machine is was my father in law and he purchased brand new. I'm 99% positive he hasn't changed anything other than a couple hydraulic lines, since he's the type of guy who doesn't touch anything unless it doesn't work . Needless to say, I've got my work cut out for me.
Old 06-03-2015, 08:05 AM
If you have the later 2082 w/ the 6" PTO and the correct belt (954-3047), then there has to be something in the way the Mule Drive Adapter to attached to the tractor.
