Old 06-15-2010, 10:22 PM
burny36 burny36 is offline
Default which carb will fit??
i have a k361 18hp engine and i was wondering what carb will fit it? do i have to get the k361 carb or could i use one off of a 20 hp or maybe a 16 hp engine?
Old 06-16-2010, 02:53 AM
young enthusiest's Avatar
Do you have the old carb?
Old 06-16-2010, 08:56 AM
What model of Cub Cadet is this motor in...??
Old 06-16-2010, 11:05 AM
Old 06-17-2010, 10:56 PM
i do have the old carb but it is missing some parts to it that i cannot find.
the engine is out of a simplicity but not many simplicity people know about kohlers. im putting it in my cc 123.
Old 06-20-2010, 04:25 PM
does no one care anymore because i said simplicity or what?
Old 06-20-2010, 05:15 PM
Nah, most of us haven't got 18 HP engines! Besides, there's nothing wrong with a good Simplicity either..
How are ya gonna fit that in a 123?...Gonna have to mod the frame or are you changing out the flywheel, etc?
Old 06-20-2010, 05:31 PM
I don't think the block will fit anyway...that's one of the wide base versions. If there isn't an "A" in the model number (as in K361A) it will not work anyway.
What on earth do you want that in there for, anyway? A good, strong 12 hp will do everything you need it to, and shake a lot less than that K361, for which many parts are NLA.
Old 06-20-2010, 06:11 PM
jbollis's Avatar
jbollis jbollis is offline
Actually those blocks will work with a little time on a mill. Most are already drilled for the cub cadet oil pan,and if not the blocks have stock where needed to do so. Then by filling in the windows on the two sides ( either by welding or making inserts) and milling the ears of they are no different than the A series. I do not know if the frame will need clearanced or not on a 123. But I know they will fit in a spreadframe.
I would like to find a complete 18. The one I have is missing the head and carb. Then I would put it in my 1211.
Sold everything but one.
Old 06-23-2010, 08:55 PM
i got the cub from my grandfather. i remember riding with him on it around the farm when he couldn't walk so good. he is long past and i want to restore it while still being able to use it to its full potential. the cub has a briggs 8 hp in it right now and the frame is already modified. so since its modified already ill just widen it a little and make it work. the 18hp i got for free from a buddy and all it is missing is a carb. i have gotten a carb from a same era 14hp and i was hoping that will work.
i don't have a deck or anything for the tractor so im just going to use it to pull things around the yard. but realistically it will just sit and look pretty and ill drive it when i feel like it.
