Old 06-04-2015, 05:44 PM
JLM78 JLM78 is offline
Originally Posted by timbo2 View Post
Total carnage-
looks like the governor bit it too, wonder if that happened first. There are small chunks broken off the bottom of the cylinder bore so I assume this is a goner.
This is what my Govner look like
Old 06-04-2015, 05:50 PM
timbo2's Avatar
timbo2 timbo2 is offline
I'd say the rod sized on the crank and that started the problem.
Lets see some pictures of the block spigot, many times a chunk out of them causes no problem.
Clean up the crank,prolly .010 under, do what is necessary to the bore, check/do the valves and you are back in business, and you will have a "new engine" rather than some turpentine overhaul used one from evil pray or ??
----just my $.02.:Blah'b;Blah:
George - what is the 'block spigot'? should get more pics later.
thanks
- Tim
Old 06-04-2015, 06:11 PM
It may be rebuildable, it all depends on the block and crank.
Old 06-04-2015, 07:35 PM
sorry,
the part that is chipped out, the part that extends
into the crankcase.
Many times they take a hit ( chipped out) but the block can be reused.
Many an engine of various kinds is running just fine with a chipped spigot or extension of the cylinder bore if you prefer.
it depends on the severity of the damage.
Old 06-04-2015, 07:47 PM
timbo2's Avatar
ah I see what you mean. I was wondering that since the piston doesn't go down that far.
However I think I saw a crack extending up another inch or so. May get a pic soon. Too full from dinner!
thanks
- Tim
Old 06-04-2015, 08:06 PM
thanks
when pullers build stroker engines that part gets ground off anyway so i doubt it will hurt.
Old 06-04-2015, 08:21 PM
timbo2's Avatar
OK- I was wrong there is no crack extending past the chipped parts. cross shaft tab broken off too. It must have over RPM'ed.
- Tim
Old 06-05-2015, 03:56 AM
You don't know if it over-revved? Weren't you there?
The block may be salvageable. Get it magna-fluxed (crack checked).
Old 06-05-2015, 07:18 PM
timbo2's Avatar
I finally got the camshaft out. Reread the manual about 5 times because I swore I was missing something. Just needed a bigger hammer.
Where are the timing marks on the crankshaft? I see a stamped 'D' and 'c'. is it the 'c'?
I also see the mark on the edge of the camshaft gear.
thanks all-
- Tim
Old 06-05-2015, 07:38 PM
On your connecting rod cap- Was the oil hole towards the cam or away from the cam before it blew?? I've seen this a few times and it ends up looking like what you have. If it was away from the cam, it won't get enough oil to stay lubricated, especially at higher RPMs.
