Old 06-06-2015, 01:39 AM
Thank you Don. Do you agree with Mr. Almighty that there's no way it's rings? Correct me if I'm wrong but doesnt poor ring seal pressurize the crankcase and "make oil come out of the breather" or "make oil come out of the dipstick"? It may or may not be rings but the symptoms he described certainly point to that IMO.
I sincerely hope that you were not referring to me. I suggest you tone it down.
Sure, poor ring seal can add pressure to a crankcase. But not likely that much.... and not all at once. Rings don't just "let go" all at once like he described in the first post. Only other possibility would be a hole burnt in the piston, but I'm doubting that. We will see if "Mr. Almighty" nails yet another diagnosis here shortly.
