Old 06-09-2015, 10:09 PM
john hall's Avatar
you probably should read up on Onans in the engine section. Here is a link posted there to a good read:
http://www.mytractorforum.com/280-sm...an-engine.html
Hopefully the damage is just a rod.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-09-2015, 10:12 PM
elshiv's Avatar
elshiv elshiv is offline
Yes I found that thread. It's awesome! Thanks for the reply. Yeah I have my fingers crossed its just the rod.
Javier~
1980ish 982 w/ 3pt. & PTO /50C deck - a Work in progress. Brinly Moldboard Plow.
I'm a complete noob at this so please take it easy on me.
Old 06-10-2015, 10:07 AM
CubDieselFan's Avatar
You said you are a newby so I just going to give you some advice. Repower the tractor and you will be money ahead and have a great tractor for years to come. Rebuilds can get expensive and they do not always turn out good. Just my .02.
Old 06-10-2015, 10:59 AM
elshiv's Avatar
Understood.. honestly I want to see if I can do it.. if it's more then just a rod I will probably do a repower with a Kohler Command. I just hope I can find something with as much torque thats not crazy expensive. A little quieter would be nice too.
Javier~
Old 06-10-2015, 11:11 AM
cadzag72 cadzag72 is offline
Kudos to you for being willing to give it a shot! Remember, if you get to a spot you feel over your head, you've got a great support group here. You've got a cub a lot of people drool over.
Ian
Old 06-10-2015, 12:19 PM
john hall's Avatar
If you go the repower route, there are folks that would buy whats left of the Onan, don't send it to the scrap yard.
2072 w/60" Haban
Old 06-10-2015, 05:58 PM
elshiv's Avatar
Understood.. I know they are rare.. it's another reason I want to fix it! So along those lines!...
What's the best way to clean the heads?.. they are filthy, probably why it had a breakdown.. probably an overheat issue.
Javier~
Old 06-15-2015, 08:55 PM
elshiv's Avatar
So I finally got the process started today. I got the 982 into my garage on its own power. I disconnected the battery greased the terminals and taped up the cables. I was able to remove most of the shroud. Except the piece the is on the left side. Seems like there is a bolt under the oil filter somewhere I can't find a way to get to. The exhaust came off next, that wasn't too bad. However it was really rusty stuff. I put the bolts in a vinegar bath to see it I can clean them up some. I can see 2 of the 4 bolts that hold oil pan down.
It's there a easy way to referb the mufflers? I'd like to refill them with steel wool or fiberglass.
I also found that the carb was not bolted down to the intake manifold! That can't be normal... Can it? .
I'm putting all the parts in plastic baggies as I go. Looks like PB Blaster is going to be my friend! I better go buy some stock!
I'll upload pictures shortly. I also found a guy selling an Onan P224 cheap! Would it be difficult to set that up to run in the 982? He says it has low compression and needs new rings. I'm wondering if it would be worth it?
Javier~
Old 06-15-2015, 10:03 PM
john hall's Avatar
You pulling the air shroud with the engine in the tractor? I don't think it was that big of an ordeal to pull the engine from mine. Had to remove a rat nest from mine. Take a good look at the driveshaft and its components while the engine is out. Won't be surprised if all your wear items are shot. I even had to replace the shaft on mine. Before you pour a ton of money in the engine price out what it would take to rebuild the driveshaft--anywhere from a few bucks to around $150.
I didn't bother the mufflers on mine, seemed fine to me. If memory serves me correct you'll notice one of them bolts on kind of crooked. Its behind the grill, your neighbors with green machines won't notice. Seems they have an odd open end slot arrangement for bolting down with.
Oh yeah, snug up your steering box with the motor out, a lot easier this way. Don't get it too tight or it will be a bear to turn once you put the engine back in (don't ask how I know).
2072 w/60" Haban
Old 06-15-2015, 10:47 PM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
[IMG]https://dl.dropboxusercontent.com/u/1556119/My%20Cub%20982/IMG_20150609_180027.jpg[/IMG
I sand blast my heads, that is, if you have a sandblaster
1961 Original
1962 original w/ fenders and creeper
102
72 w/ fenders and lights
124 w/ sleeve hitch
129 w/ lights
5 mower decks, 2 plow blades, 1snowblower
