Old 06-24-2010, 07:51 AM
gcbailey's Avatar
gcbailey gcbailey is offline
Ya, they are the auto ones. I got a good buy on them, so I decided to go for it. The release lever "flap" was broken off so I ordered a replacement, then I found those valves... that's how it goes.
Gary
Old 06-24-2010, 12:05 PM
I'd take the automatic valves over the manual ones anytime.
Old 06-25-2010, 06:41 AM
gcbailey's Avatar
Originally Posted by TEET View Post
You are correct..Its been, "sort" of repaired in the past. It may work, but Its not really the proper repair for a worn trunion. Check out this http://www.onlycubcadets.net/forum/s...ead.php?t=4635 to give you a better idea of what it should look like. It may work ok as-is, but its possible that it could prematurely wear out other parts for the trunion. Interesting repair, I've seen lots of Cubs with trunion repairs, but thats a first for me
Jeff (teet)
Should I look at replacing all three pieces #1, 7, 9 or would just getting shims as mentioned other places work?
Gary
Old 06-25-2010, 08:30 AM
I would shim #1 and leave the other two alone. 7 and 9 don't really wear all that much from what I've seen, and replacing #1 may not even help, since there is probably also wear on the trunion shaft, as well. It's the trunion slot that needs some help on yours.
Old 06-26-2010, 05:56 PM
gcbailey's Avatar
OK another question.... If I fab up the fix piece for the trunion bracket, does the rectangle just weld on top of the existing one, or do you have to cut it then weld?
Gary
