Old 06-17-2015, 09:18 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Default Anyone built a poly pipe for lawn irrigation "pipe layer"
For their Cub Cadet.
And have pics to share?
I am imagining a hunk of 2" steel pipe with an easy sweep 90 degree bend.
Leading edged with steel plate to make like a cutting edge.
Coil of poly pipe would be up above vertical end of 2" pipe.
My yard is basically grey beach sand and I only have to lay it in 6 or 8" deep.
Old 06-21-2015, 12:41 AM
cub123's Avatar
cub123 cub123 is offline
May not be much help, but I've watched this video a few times and think it's a cool setup.
https://m.youtube.com/watch?v=KsFMsrnXAv8
Old 06-21-2015, 08:00 AM
I remember seeing what your talking about in the home made section of MTF.
http://www.mytractorforum.com/
Basically a sub soiler with a pipe sweep behind it.
http://www.mytractorforum.com/78-law...type-tool.html
http://www.agrisupply.com/point-pipe...ipper/p/73622/
Old 06-22-2015, 10:39 PM
sawdustdad's Avatar
I built a cable layer with a long sweep elbow of 2 inch metal conduit strapped to the back of a subsoiler. Pulled it with my Ford 2000. Buried lots of direct burial UF cable. Would easily handle putting in irrigation pipe. Might not have enough traction with a cub cadet unless your soil was very soft, so you might want to rent a 4wd sub compact or larger tractor with a cat 0 or 1 hitch.
Old 06-22-2015, 11:22 PM
I think it will pull it, no problem. If I can pull a moldboard plow 5-6" deep in Illinois clay, he can surely pull a single rip shank 8" in sand.
Old 06-23-2015, 04:50 PM
DoubleO7's Avatar
thanks guys!
it will be a single time use so it ain't gonna be pretty!
