Old 06-24-2015, 12:54 AM
BigB87's Avatar
BigB87 BigB87 is offline
Default Kind of stumped
I might be trading my 582 for a 682 but the guy says it's red and made by mtd..mine is by ih
Is he right or wrong? I llovemy 582 but need something bigger to mow with
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 06-24-2015, 01:54 AM
cubby102's Avatar
cubby102 cubby102 is offline
Yes he's correct. It should also have a black front and rear axle. Rear axle can be eather cast iron or aluminum. Red ones were sold at ih dealers and yellow were at cub cadet dealers.
Old 06-24-2015, 02:33 AM
BigB87's Avatar
Well i havent seen it yet. Said has the the series 2 kohler twin. Would i be down grading since everything I have is ih or upgrading. Has 50 deck and i have 44
Brandon
Old 06-24-2015, 02:41 AM
cubby102's Avatar
About the only real difference between the two the then the series two would be the paint and if it had a aluminum rear diff. Which personaly I've never had a issue with. Cut just as well and are just as usable as the ih built one. If it is a real early one it may have the cast rear which in that case the only real difference is the paint... personaly I like 582 better then 682s. But I'm quite fond of gear drives.
Old 06-24-2015, 02:45 AM
BigB87's Avatar
Me too but i rarely use my 582 other than when at shows drive it around to see things
Brandon
Old 06-24-2015, 03:07 AM
I guess I'm missing something because I'm not understanding.
The 582 is a 16 hp gear drive and the 682 is a 17 hp hydrostatic drive.
The same mower decks were available for both machines. And with the hydrostat transmission demanding more power to operate than a gear drive transmission, your 582 is just as capable of a machine as a 682.
Besides hydro/gear drive transmissions the only other real difference between the two is the 682 has a Kohler engine where the 582 has a B & S.
So how come you think there is enough difference that you want to trade?
Old 06-24-2015, 03:16 AM
Hydrostatic transmissions do not take more hp to run, they do not transmit as much hp to the ground. Hp efficiency is the difference.
Old 06-24-2015, 03:20 AM
BigB87's Avatar
My only thing is that its mtd not ih...everything I have is ih or ji case. Love kohlers but my 582 is the first red cub i ever got. I dont mow with it just show it at shows. I mow withbmy 1650 and its a power house...guess my thing is how reliable are the series 2 kohlers cuz ive never owned one
Brandon
Old 06-24-2015, 03:29 AM
BigB87's Avatar
Plus the guy wants to trade me even. 682 for my 582..
Brandon
Old 06-24-2015, 03:43 AM
OH MY GOD, Once again I've worded something incorrectly and was busted by the correct police.
