Old 06-24-2015, 10:04 AM
OH MY GOD, Once again I've worded something incorrectly and was busted by the correct police.
Oh, I'm sorry. As I read it you didn't know the difference. That's why I stated the proper information.
OP, you are worried about nothing. You are trading a gear driver for a hydro. Obviously this is some kind of big deal to you. If your not comfortable with the deal, don't do it. They are equally built machines, just different transmissions and engine manufacturers. Basically it's the same difference between a 756 gear drive and an 826 hydro if you want to think about it in IH tractor talk.
Old 06-24-2015, 10:36 AM
Terry C's Avatar
Terry C Terry C is offline
If you want it to mow with, you will be better off with the hydro.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-24-2015, 11:16 AM
BigB87's Avatar
BigB87 BigB87 is offline
Well only problem is that i mow with a hydro now and it's fine just seeking input on a 682...
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 06-24-2015, 11:55 AM
That's a matter of opinion, I prefer gear drive.
Old 06-24-2015, 03:28 PM
I think eye have a better idea,
sit and drink cold ones and watch the young thang' next door mow her bumpy yard
Old 06-24-2015, 04:57 PM
Terry C's Avatar
That's the right answer!
Terry
3225
Old 06-24-2015, 05:09 PM
Rmowl's Avatar
Rmowl Rmowl is offline
In regards to the Kohler II, the one in my 1981 782 is original and untouched. It has more than enough power for what I use it for which is a tilling machine. It does smoke a little at start up. I like mowing with a gear drive personally.
-Rick
IH 782
IH 126
CCC 1863
Old 06-25-2015, 12:37 AM
I used to mow all of the time with a hydro, but in the last two years have been mowing with a gear drive and find it a lot of fun. It really goes down to personal preference. You have to decide if it is time to try a change. Not all change is a good change. Take it for a test drive and see what you think. Whenever you are faced with a tough decision, reflect and pray on it....then listen. Let us know what happens in your deal.
Best regards,
Old 06-25-2015, 01:38 AM
I've been mowing with hydros for 20 some years and will continue to mow the "tight" areas of the yard (around the house and where the bushes and such things are)
BUT for the past couple of years, I've been on the look-out for a respectable old 128 that I can rebuild a 14 hp Kohler for, to mow the bigger areas of the yard (including the Highway ditches). I think it's time to set back and relax a little while mowing, instead of constantly having a hand on the hydro lever adjusting ground speed to compensate for varying conditions.
Oh my gosh, I just realized that in my mind, I really do think I need a designated tractor for EACH job/attachment. And to think, I just had a conversation with a friend about others who have "disorders"... What a mess this is turning out to be.
Old 06-25-2015, 07:38 AM
mickb72 mickb72 is offline
Default cub
Hey Yo Sam i/ve allways heard you have to have a tractor for every implement. I/ve slowly worked that my way, not that i intended to. Works out good for some things. Covered space is limited. I/m one tractor over the line sweet Jesus. Mike
