Old 07-01-2015, 08:37 AM
When you get a second see if you can get the serial number for that critter.
Looks like they may have used a couple different trannys in them.
Here's a link to a PDF from Husky showing the trans, not sure if it's the correct one for your mower.
http://www.husqvarna.com/ddoc/husi/h..._i0002002_.pdf
PS: I think Justin may be right on this one.
Old 07-02-2015, 12:13 AM
Thanks Sam, that looks like the animal.
Old 07-02-2015, 10:39 PM
Nuts on Justin, the link you gave me was right on, thanks.
Found that the one check valve that sits inside of the oil filter had backed out and fallen out of its hole.
Old 07-03-2015, 06:31 AM
Glad to hear that you got it fixed and that Justin helped.
Old 07-03-2015, 01:09 PM
Now you need to get that thing traded off on another Cub Cadet before it craps out on you again.
Old 07-03-2015, 01:32 PM
bocephus1991's Avatar
I didn't kno any of those had any kind of hydro filter or screen.
Brian
Old 07-03-2015, 03:21 PM
Justin Witt Justin Witt is offline
Man am I good or what? Looks like I'll have to start looking into working on trans as well as engines
Old 07-03-2015, 03:35 PM
I was going to say good yob on the assist J but it seems that you have already put yourself over. (Modesty is the second best policy)
Glad you got it fixed Todd
Old 07-03-2015, 04:30 PM
Or what.
Old 07-04-2015, 08:30 AM
Okay Justin, pat your back, you did good.
Anyway there is a screen filter on the top inside the fill hole. I loaded the tractor and took it to my buddy's shop to help me with it... he actually took the until out and got it on the table to work on it.
Found the trouble right off. So again thanks for all the ideas along the line
