Old 07-03-2015, 01:16 PM
thadscub's Avatar
thadscub thadscub is offline
Default Possibily building a loader
hi guys i bought a cub cadet 122 and was thinking about building a loader on it whats your thought are they worth it or not will not be using to dig alot more just moving material
thanks thad
Old 07-03-2015, 01:33 PM
Thad
I moved this to the implements section.
Old 07-03-2015, 11:00 PM
gt383mag's Avatar
gt383mag gt383mag is offline
Thad mine gets used almost everyday
Old 07-03-2015, 11:35 PM
cub123's Avatar
cub123 cub123 is offline
I use mine all the time too, they will dig ok, but they are great for moving material
Old 07-04-2015, 05:11 PM
gdheck's Avatar
gdheck gdheck is offline
cub123,
What kind of weights are those? Got a part #? I'm always looking for something cheaper than the Deere weights I use.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 07-04-2015, 10:53 PM
cub123's Avatar
Originally Posted by gdheck View Post
cub123,
Those are #808 Ford weights for the front of something like a 1710/1720 etc. Our New Holland / Ford dealer went out of business and I got a decent deal on them.
Old 07-05-2015, 01:36 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
My OPINION, loaders are junk on a cub cadet. Other than the cool factor, most look disproportionate to the cub they are on, and make the tractor clumsy to use for other jobs.
They are slow to raise and lower, and are a half a day project to mount and remove from the tractor
They put an extremely large amount of weight on a front end not built for that type of work... with out anything in the bucket. Leads to all kinds of front end and steering issues. Plan on re building your steering column and replacing your tie rod ends often!
They remove weight from the rear end which, since cubs dont have front wheel assist... seems rather silly to me!
They are not good for digging in anything but a pile ...efficiently.
Lastly, y do you want one? Are you loading material into a pickup daily? Weekly? Monthly? If you just plan to use it for moving loose material from here to there, or are actually going to try to dig, build a johnny bucket type apparatus.
Save your money, your tractor, and your frustration. If you really want to get the best of your tractor with digging and hauling, put a bucket on your cub cadet 3 point.
Puts all the weight on the only two wheels that are driving your rig. Rear axles are heavier than the front by a mile and therefore no damage to your front end!!
Ok so you have to turn around to load and dump... big deal. Your only doing it for a few hours. If your using it so much you have to get neck surgery. You need a skid steer not a cub.
Good luck...
Old 07-05-2015, 08:22 PM
Good luck...
wells aren't you just a ray of sunshine.
Old 07-05-2015, 09:59 PM
bocephus1991's Avatar
Somebody needs a snickers bar! Lol
Brian
Old 07-05-2015, 10:30 PM
I wish Rescue11 would tell us how he really feels and not sugar-coat it so much.
I like my loader a lot, I pick up and move 55 gallon drums of oil with it quite often.
Yup their's a lot of strain on the front axle, front wheels and steering. If you don't want to be broke down long, better keep an extra set of all related parts on hand ready to go.
You really do't want it on a gear drive tractor though, you just don't have enough hands to do everything with. Hydro with a F/R foot pedal.
