Old 07-08-2015, 01:58 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
Default Find of the day
I picked this up this morning for fifty bucks. No clanking sounds,compression on both cylinders, no big holes anywhere, and complete carb to starter. Came out of a 2000 series Cub showing 675 hours. I got the drive shaft except for the drive flange on the trans. I have to go back with a bigger hammer and longer bar to get that. Now I need to find the thread on adapting the drive shaft to older tractors.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 07-08-2015, 02:25 PM
jimbob200521's Avatar
VERY nice score, score of the week in fact!
What's it going in?
-Ryan
Old 07-08-2015, 02:33 PM
RR1862CC's Avatar
For now it is going under the bench. I have a freshly built M18 to go in the 1862 but I might get the pieces I need to bolt this one in the 1862 at a later time. Plus you never know what might come along needing an engine. I have enough spare frames and parts to build a franken tractor of some sort,lol.
Allis Chalmers 416
Brinly 10"plow
Old 07-08-2015, 02:35 PM
Too bad I don't live closer, I'd double your money right now!
-Ryan
Old 07-08-2015, 02:45 PM
RR1862CC's Avatar
Yeah but you know how hard it is to get a Cub hoarder to part with his stash
Allis Chalmers 416
Brinly 10"plow
Old 07-08-2015, 03:09 PM
Justin Witt Justin Witt is offline
What's it going in?
More like score of the year!
Old 07-08-2015, 03:59 PM
So it has small holes?
Don't bother with the adapter to the trans for the 2000 series. It's a tapered thing that doesn't fit anything but the Hydro Gear pump in the 2 & 3000 tractors. If you need one I have a few.
Old 07-08-2015, 04:34 PM
RR1862CC's Avatar
Thanks Sam
I will put it up for a future project, maybe a Super or Super Smoker. I found your thread on what it takes to make it fit so i have what I need for now.
Allis Chalmers 416
Brinly 10"plow
Old 07-09-2015, 08:21 PM
RR1862CC's Avatar
Worked on the Command a little today. After figuring the wiring out I hooked it to my run stand hit the button and she fired right up,sort of. The right cylinder(left sitting in seat) is dead. After checking it over I found no spark on that side. It has a pretty big oil leak behind the flywheel also. For now she goes under the bench until I have more time to check it out but I am pretty happy so far.
Allis Chalmers 416
Brinly 10"plow
