Old 07-09-2015, 05:15 PM
mrmiller mrmiller is offline
Justin:
Go here........ AC Forum
I am quite sure the experts there can handle this problem.
X2!!!!!!!!
Old 07-09-2015, 06:31 PM
Guys the kid is asking for help not a bunch of crap.
Justin
1: No the fuel can not be gelled because it's too warm that happens when it get's cold enough for the paraffin that is a component of diesel settles out of the fuel and plugs the filter.
2: If the tractor has been sitting for a long time you could possibly have algae in the fuel. Drain the tank, clean it out and blow out or flush the fuel lines.
3: Replace all of the fuel filters and refill with fresh fuel.
4: If the above measures don't fix it then it probably has a problem in the pump or injectors.
Old 07-09-2015, 09:54 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
All good ideas. Try the guys at www.allischalmers.com for more more info. They know A/C like the people here know Cubs.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 07-09-2015, 10:07 PM
Justin Witt Justin Witt is offline
Justin
Thanks sam. Ill try these.
Old 07-12-2015, 10:46 AM
Grampie Grampie is offline
Sounds like the machine is wore out and in need of a total rebuild with all the blow by coming out of the breather and the loss of power once it warms up.
Either prepare to spend Thousand's of $$$$$$$, or save $$$$ by getting a torch and cutting it up into 2foot x 3foot pieces for #1 prepared SCRAP.
Now that's some Valuable Information, FREE OF CHARGE !
Old 07-12-2015, 11:23 AM
Ya thats what should have been done years ago. But they decided to put in a new trans and the engine was rebuilt a decade or so ago. (not very good rebuild)
