Old 07-17-2015, 02:09 PM
snoel's Avatar
snoel snoel is offline
Default Digging, (plowing up) Patatoes
Putting the new hitch and plow to work. (hitch, Customized Cubs). Plow, rake out, pick up, wash, spread out on the grass, to dry. Much easier than last year, with a shovel. One row done. Two more to go.
Steve
Old 07-22-2015, 05:26 PM
biglefty's Avatar
biglefty biglefty is offline
Default Finally got a start on the wood for the winter
Finally got a start on the wood for the winter. I like to do this in the spring but seem to get started later every year
Old 08-05-2015, 10:27 PM
IHinIN IHinIN is offline
While replacing a leaking head gasket on my 129, I managed to drop a nut into the flywheel shroud. Of course the only way to get it out is to pull the engine. While the engine is out, I decided to replace the leaking front crank seal.
Old 08-06-2015, 07:18 PM
I finally cleaned up and organized my outdoor parts area, when I got done with that I worked on a belt problem I've been having with my sons Cadet 111.
Old 08-09-2015, 02:20 AM
You Guy's have been busy.
Great pictures
Old 08-11-2015, 03:58 PM
Tony h's Avatar
Tony h Tony h is offline
Made some end plates for the snow plow. they slide on and off easily with the removal of some "R" clips. There are times I wanted the plow to act like a 'Pusher'. Not painted yet so it looks very bad. After a trial run this winter I will make whatever Mods I find it needs, then make it pretty.
If I can't fix it , it must not be broken
Old 08-13-2015, 09:18 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Default Haven't posted here in a while...
Yesterday I got all the runners out for some fun. Mowed some grass with the 1864, graded the driveway with the 782, and hauled some stuff with the 2372 and 102.
I also chased the dog on the atv and bush hawged with the deere.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-13-2015, 10:57 PM
didnt i sell you lights for that 102? where are they?
Old 08-13-2015, 11:08 PM
Shrewcub's Avatar
The 102 has a K301 in it and is going to get a better one with a new clutch and 122 hood and grill. Hydro lift will go on then too. I had the grill out for pto repair and just didn't want to waste the time putting it back in to come right back out. I am going to put all the best NF parts I have in this one. So in the end I will have a 122 with a 102 seat.
Got a few other projects going on too! I will get to it, I promise!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 08-23-2015, 08:22 PM
Gave the June 61 Original a bath today with some help from the Bota
