Old 07-23-2015, 02:56 PM
Shaner Shaner is offline
Default Category 0 48" tiller
im currently in the works with someone about buying a category 0 48" tiller for my 2072...are there any experts on these tillers? all i know about them is they are 2000RPM, they are heavy, you need a rear PTO (i have one coming), they are heavy, they seem to be harder to come by than the 42" IH tiller....and they are heavy. thats about all i know.
anyone on here can tell me the pros and cons and what to look for on this tiller? from the photos the man sent me...it looks to be in good shape! he bought it from Houtz.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 07-23-2015, 06:06 PM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
I heard they are heavy. But other than that, they are quite heavy.
Old 07-23-2015, 06:28 PM
Good thing I got heavy things to hang off the front to make it more heavy to pick up the heavy tiller!
Old 07-23-2015, 09:23 PM
Hey Man,this is getting heavy....
what does one pay for such heavyness?
Up to 534 and counting...
Old 07-23-2015, 09:32 PM
I have 2. IIRC they are heavy. Problem is, I never used either one yet.
The Cub.
The Snapper.
Old 07-24-2015, 11:35 AM
Looks like it weighs quite a bit also.
Old 07-24-2015, 12:14 PM
Leadslingingdaddy's Avatar
Used mine numerous times....Chews up virgin soil like a beast.... nice and smooth when done and best run deep.....Its heavy and a man handler though have at least 100lbs up front...makes steering much easier
Old 07-24-2015, 09:49 PM
red56turbo's Avatar
I've got one, too. And it is pretty heavy.
I'd buy it if you're in the market. They don't come up for sale too often and can be pricey. Good luck!!
Josh
Diesel Cub Cadets...........
Old 07-25-2015, 09:43 PM
barkerwc4362 barkerwc4362 is offline
Default Yellow tillers
The yellow 48" 2000 rpm pto tillers weigh around 450lbs. It is recommended to have 8 42lb suitcase weights on front of the smaller tractors and 7 weights on the larger tractors. You can move them with 4 weights installed, but having all the weights installed up front are definitely a must when tilling. I speak from experience. Make sure you check and change as necessary the oil in the gearbox.
Bill
Old 07-25-2015, 10:03 PM
I am thinking about adapting this one to my Super.
I think it would be an easy adapt,,,, all it needs is a belt to spin the pump then it will run,,,
the pump can be mounted anywhere,,,
the hitch will be easy to connect,,, the JD guys love them,,,
