As the title suggests, I have a friend who is looking for a mule drive for his Quietline. The only one I have is from a 682/782. Would the newer mule drive play nice with a Quietline?
![]() Personal opinion: I don't see why not, the only difference I know of is the pulleys would be 1/2 instead of 3/8 or whatever the case may be but should still work. Am I right or crazy? Or both?! ![]() ![]()
-Ryan
I can't remember which one , but the pulleys/shaft are in a different location between the two. One sets farther back and the other forward.
I think the pulleys on an 82 series mule drive set farther forward ?? I tried it once and the PTO belt had a severe angle. I never tried to run it like that , didn't want to try. |
I think the 82 series is set forward & don't think it'll work (the pulleys won't sit perpendicular to the PTO like they should). The Q-line/1x8-9 mule is quite a bit smaller and shorter as I recall.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
The mule drive off a 1211 I know will not fit an quietline. It interferes with the latch. I assume the 1211 is like an 82 series.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Thank you gentlemen, I wasn't 100% sure but seems majority knowledge has out-ruled my guess
-Ryan
I could be wrong, I tried putting the quietline mule drive on the 1211 and it wouldn't fit.
