Old 08-01-2015, 11:14 AM
timbo2's Avatar
timbo2 timbo2 is offline
Originally Posted by R.Parker View Post
Carb was completely tore down and sprayed with carb cleaner and blown out with air. I havent adjusted the governor arm. Be honest I have never done that nor have a manual to do so.
Welcome to OCC BTW!
Here are some links to help:
k series manual to download
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
Gov adjustment
http://cubfaq.com/govadjust.html
- Tim
Old 08-01-2015, 11:29 AM
R.Parker's Avatar
R.Parker R.Parker is offline
It idles great. Soon as you try to give it gas it misses like crazy and it will idle it self down. I have a video but it won't load.
Old 08-01-2015, 11:36 AM
R.Parker's Avatar
Originally Posted by timbo2 View Post
Welcome to OCC BTW!
Gov adjustment
Thanks pal !!!! Will give this a try
Old 08-01-2015, 11:41 AM
timbo2's Avatar
No problem, take your time.
you have some smart guys here but nothing can help more than reading the manual.
- Tim
Old 08-01-2015, 12:08 PM
timbo2's Avatar
Also - I've had gov. problems cause high RPM's but never the other way around.
Still thinking fuel or timing.
- Tim
Old 08-01-2015, 12:14 PM
R.Parker's Avatar
How would a guy adjust timing
Old 08-01-2015, 12:42 PM
timbo2's Avatar
pg. 8.2 in the manual
also spend some time in the tech library on this site. just about all you need including how to time the engine:
http://www.onlycubcadets.net/forum/f...splay.php?f=19
- Tim
Old 08-01-2015, 01:30 PM
R.Parker's Avatar
Adjusted the govenor....no change in behavior. Going to check timing... also when it's cold tractor runs it's best. I usually can mow for 5 Mins than it really starts the missing. Thanks again fellers
Old 08-01-2015, 01:51 PM
As far as your "idling down by itself" issue, have you checked the throttle cable where it connects to the engine linkage to be sure that the cable did not come loose from the clamp? If that is tight, then the only thing I can think of is that your throttle handle in the dash is loose. There is a screw that holds the handle to the mounting bracket, and if the friction washer comes loose they will idle down themselves. BTDT many times. Just something to check.
Old 08-01-2015, 02:28 PM
R.Parker's Avatar
I am happy to report that it was the timing. Point was set at .30 brought them to .20. Runs pretty good. Had to set governor up a tad but it runs well. For 275 bucks and having all the new parts on it already I can't complain. Just wish I could up load pics...son of a....
THANKS FOR THE INFO AND TIME !!!!!
