Old 07-31-2015, 11:51 PM
gdheck's Avatar
gdheck gdheck is offline
Default Cyclops click when starting question
I have a question for those of you who have experienced the click and no crank problem with a cyclops. Did you notice what the starter did? I have done the gear reduction starter upgrade and didn't have this problem again until lately. The battery and cables are only 2 yrs. old and the battery is fully charged. A lot of times now when I turn the key I get a click and the drive gear on the starter is out against the ring gear, but it doesn't turn. If I tap just lightly in the area of the upper mount bolt, it starts cranking. The mounting bolts are still tight.
To me, when I have to do this it's just as embarrassing as running out of gas right in front of the announcer during the parade at a tractor show would be. Thankfully, I have never had that happen.
Thoughts?
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 08-01-2015, 12:07 AM
jimbob200521's Avatar
Common problem, check this out:
http://www.onlycubcadets.net/forum/s...ad.php?t=38545
-Ryan
Old 08-01-2015, 01:36 AM
gdheck's Avatar
I was aware of that problem, but I was wondering if that is actually what is happening or if my exact problem is a unique one.
Old 08-01-2015, 04:29 AM
Yes, and no.
Old 08-01-2015, 07:29 AM
A lot of times now when I turn the key I get a click and the drive gear on the starter is out against the ring gear, but it doesn't turn. Thoughts?
Sounds like you need the relay fix to me.
If you can jump across the battery cable to the small terminal on the starter and make it crank, I'd add the relay.
Or, if you put a battery charger on the battery for a few minutes and it starts, another sign the relay might solve the problem the easy way.
My experience on Kohler Command anyway.
Old 08-01-2015, 08:21 AM
When it is "clicking" but not spinning, check the voltage @ the starter terminal, on the starter, that should tell you if you have a sol problem or the armature/brushes need attention.
And /or as others mentioned, using a heavy wire or screwdrivers jump the 2 heavy terminals on the sol, that will essentially eliminate the sol from the circuit.
Old 08-01-2015, 12:54 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Just bought 2 solenoids. How's the repair working for you so far??
