Old 08-03-2015, 05:14 PM
zimm17's Avatar
zimm17 zimm17 is offline
Default Shot spindle?
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 08-03-2015, 05:54 PM
I give up, what is that from? I know it's not a deck spindle.
Old 08-03-2015, 05:56 PM
zimm17's Avatar
Front right wheel. Bearings were bad and when I wiped grease off I saw that! A new one is $190! Ouch.
1973 Cub Cadet 149
Old 08-03-2015, 05:57 PM
shouldn't hurt anything, id run it.
Old 08-03-2015, 06:26 PM
rwairforce rwairforce is offline
Agreed.
Get a new bearing or two and run it.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-03-2015, 06:33 PM
freedhardwoods's Avatar
freedhardwoods freedhardwoods is offline
I'm a new guy here. I know some will laugh, but JB Weld and sandpaper will make that look almost new and last as long as the tractor.
You'll want to file or carefully grind down any high spots first. Put on the JB and let dry. Sand slowly. Check the (new) bearing fit often. When it goes on snugly, your ready to put it together.
I fixed truck steer axle that way years ago.
Old 08-03-2015, 06:38 PM
zimm17's Avatar
Thanks. I got new bearings. I think the old bearing was spinning on that spindle and chewed it up.
1973 Cub Cadet 149
Old 08-03-2015, 06:54 PM
You can mig weld that spindle a little. Grind the high spots off so the bearings will slide on it and use it.
Old 08-03-2015, 07:31 PM
Workinprogress Workinprogress is offline
You could also try a spindle upgrade like:
http://www.loaderplans.com/spindle-upgrade
I did my 1512 years ago.
I suspect a good welding shop can remove the spindle and weld up a new shaft for a lot less than the price for new.
Could also watch evil bay or try one of the sponsors for a used one.
Good luck!
Old 08-03-2015, 08:10 PM
Someone has already been welding and grinding there.
I would run it also.
What's the worst that could happen?
