Old 08-02-2015, 11:13 PM
johns cubs's Avatar
johns cubs johns cubs is offline
X3- i also move a lot of firewood each year and just so happens that i have a small 10cu.ft dump trailer that needs tongue work and tires!
John
Old 08-03-2015, 07:54 AM
Originally Posted by Olesalt View Post
that may be used to move some round hay bails to.
They would have to be awfully small round bales to move with a little garden tractor
Old 08-04-2015, 04:54 AM
randallc randallc is offline
That's a neat idea. Does not look to light. Would certainly come in handy. Thanks for sharing.
Old 08-04-2015, 07:37 PM
Workinprogress Workinprogress is offline
Put the carry all to the test and a few minor issued developed.
The unit worked great with two rows of firewood level with the top. While I have a home made Johnny bucket on the front of the tractor I didn't require any additional front weight.
As with everyone I pushed it some more. If I pile the two rows of firewood as high as I can the front end gets light. Putting wood into the Johnny bucket solved the light front.
The resulting heavier load bent the metal plates mounting the hitch pins.
I had to add plates to handle the load.
Old 08-04-2015, 07:43 PM
Also added angle supports to help remove some flexing. The supports are bolted onto the carryall so they can be removed to use it like forks.
Old 08-04-2015, 09:31 PM
Here is the tractor loaded with wood (level with top).
I did have great traction with the carryall loaded. Even on muddy wet ground the tires never slipped.
Old 08-06-2015, 10:48 PM
red211's Avatar
red211 red211 is offline
That is a good load for sure. Looks like at least twice what my wheelbarrow holds. Looks 10 times easier to move too!!
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
