Old 08-09-2015, 01:56 PM
seanmmcc seanmmcc is offline
Thanks guys!
So it seems like it is the connectors that are in the plug on the back of the ignition that are the issue. I am taking them out and bending them slightly for better contact. I did a test run after bending the one that was broken and it ran great, no issues with the pto!
Your right it is the sensor 925-3251. I put the sensor back in too I guess hard to tell if functional?
I ran the mower in reverse and it seemed like it cut? Does the pto actually turn off in reverse?
Old 08-09-2015, 02:43 PM
How do you bend a broken terminal? Isn't broken, broken???
Old 08-09-2015, 04:15 PM
The female connector has a piece of metal that folds back where the male piece fits in it broke on a number, this is what broke:
http://www.ozautoelectrics.com/media...226__55462.jpg
Many female connectors dont piece of metal in the middle they just have tighter curls on the sides to hold the male connector. So i bent those in to take up the gap. Like this....
http://www.germansupply.com/home/ima...roductid=18232
Not ideal... but I dont have any of those with the extra piece of metal on hand and when it fails again I will replace, I suspect the wear was due to lack of wire support pulling on the connection. I added some zip ties to reduce strain.
Thanks for all your help guys.
Sean
Old 08-09-2015, 04:43 PM
I could be mistaken but Gm used those before they went to weather pack connectors.
Should be delco/packard--- try auto parts/ napa or
evil bay
Old 08-09-2015, 06:00 PM
IH used them too. They are not hard at all to come by.
Old 08-09-2015, 06:41 PM
I got some from these guys.
http://theelectricaldepot.com/
