Old 08-26-2015, 12:07 AM
Sprint60's Avatar
Sprint60 Sprint60 is offline
Default Love those yellow machines
Long time lurker here and elsewhere - I've learned a lot from you all.
Some weeks ago I was riding around on the 19-year-old Murray (don't laugh, that little fellow has worked hard all its life) and sort of had an epiphany. I don't like the look of the new stuff on the show room floor; don't think they're good value for the money. The old Murray seems to be designed to wear out; I've been announcing for about three seasons in a row that it's on its last but somehow it manages to come back yet again.
I'd seen a couple 147s on Criag's List and it occurred to me that two "bad" ones could make one "good" one. Not sure that was a good idea; I've since seen a couple on the the list that are in much better condition for about what I currently have in these two. Anyway, here's a photo (assuming it works) of the pair with the Yanmar (which is too big and heavy for general mowing - it IS good for grading the drive and moving snow.) The plan is to declare one as "it" and start using it taking parts from the other or scaring them up as needed and then restoring the other.
The one on the right runs and mows; the one in the middle still has the original clothe wiring which is pretty badly rotted out. After spending some quality time with the starter motor, I did get the engine to turn over, and after some work on the points did get it to run briefly. The carb is off soaking now. It also needs tires, the one won't hold air even briefly which makes it a nuisance to move. It has the electric lifter, but I don't know if it works yet since the wiring is in such shambles.
The one that runs has had some TLC on the steering, but needs more. The deck is missing the pully covers. No lifter. And I've replaced the front wheel bearings but the spindles are pretty worn. It will cut some grass though! I have some hy-tran, a filter, and some oil so it'll get some maintenance before it's ready for general use.
So here's a shot at the only pick:
Old 08-26-2015, 12:15 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I see a lot potential in those 2! What they don't have you might find here or from the sponsors.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-26-2015, 12:50 AM
bocephus1991's Avatar
Hello and welcome! What part of Missouri?
Brian
Old 08-26-2015, 09:19 AM
Sprint60's Avatar
Thanks! Greater Kansas City area.
Old 08-26-2015, 10:10 AM
Terry C's Avatar
Terry C Terry C is offline
Welcome to OCC! Those 147s look good. 147 was the most hp you could get in s narrow frame, I'm sure you will like them.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-28-2015, 12:02 AM
Bill410 Bill410 is offline
Welcome from another "new guy"! But be careful, having hung around gt's for a while, "parts tractors" usually don't end up that way!
"It's just too nice to part out" or "If I buy just a couple parts, this one will run as well!"
Next thing you know, you have 3, or 4, or ... well, you get the idea!
Old 08-28-2015, 02:51 PM
SGragg SGragg is offline
Inactive Member
So YOU'RE the one buying up all the 147s in the area!! LOL
Seriously, welcome to the forum! I'm just east of KC, near Lone Jack.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-02-2015, 08:43 PM
I agree with Shrewcub, both are going to be fine tractors in their own time. And heck, the 147 is a very unique tractor being the only NF that was modified to hold the 14hp engine. So I'll leave you with a phrase often heard by many women from me....."Nice pair!".
Welcome to the forum. I'm looking forward to reading about your progress on both of your 147's (and future cubs ) real soon!
Old 09-03-2015, 01:33 PM
KiwiUSA KiwiUSA is offline
That made me laugh lol
You will have both up and running in no time, I would like to get a 147, I like the idea of the 14HP
Cub Cadet 1968 105 with Spring Assist & 3 point Hitch
42'' Mowing Deck
QA36 Snow Thrower
42'' Tiller
Snapper 1983 LT1100
1967 Mustang Coupe RestoMod
