|  | Thread Tools | Display Modes |
			I found a 154 owners manual in some stuff I bought and there was a section in it about transporting it. Where to hook is irrelevant to cadets but it stated to over inflate the tires to keep bouncing to a minimum.  Like Tim I use a clevis on the back then I hook to the foot rest bar( like where the front blade pushes from)
				__________________ Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
			... set the park brake n drive like hell    |
			Something I always do on a Cyclops is to keep a small strap and wrap it vertically around the tractor toward the back of the hood to keep it from flying up. I do this no matter what direction it is loaded. Aside from that, I put a strap around whatever axle is to the front and around the railing of the trailer. I've got several hundred miles of towing this way without a problem.
				__________________ 2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck       |
			One thing my brother taught me (about bigger tractors) is to haul it outta gear, that way if something happens and moves, it won't accidentally start itself and drive itself off a trailer.  Never thought about that.  Not really an issue if you've got a hydrostat.
				__________________ Daniel G.  . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
			how would it start with the key off?
				__________________ Tim Pap's 100 Restored 108 1211 Dual Stick 1050 Pap's 100 restoration thread - http://onlycubcadets.net/forum/showthread.php?t=47965 |
			I think he is talking about a magneto ignition with a  momentary contact stop switch.
			Or a diesel. On my JD the fuel shut off creeps back down.
				__________________ Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122         JD 2155 w/ 175 loader |
			Still.....better safe than sorry IMO.
			So you guys don't just throw a chain over the hood and ratchet it down?
				__________________ More IH Cub Cadet Parts RIGHT HERE |
|   Quote:
				__________________ -Ryan    |
