Old 08-28-2015, 07:38 PM
twoton twoton is offline
Default Battery terminal corrosion
So hey guys, I was just wondering what you all use to prevent corrosion on your battery terminals. I've used petroleum jelly for years. It's cheap, works well and lasts a long time.
Old 08-28-2015, 08:30 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
That is what my dad and his dad have always used.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-28-2015, 09:26 PM
I use nothing and just clean them with a wire brush once a year, I disconnect my positive terminal after every mow so I'd rather not have anything on the terminals.
Old 08-28-2015, 11:21 PM
I use the yellow paint(battery terminal protector) since the Ford shop days, always used wheel bearing grease before that. The paint doesn't rub off on your arm like grease.
Old 08-29-2015, 12:28 AM
bocephus1991's Avatar
My Cubs, I don't have a problem with corrosion. My truck I use grease on it.
Brian
Old 08-29-2015, 07:15 PM
I don't normally use anything. Keep the acid cleaned off the top of the battery and it won't corrode the terminals. If the battery is leaking and won't stop, check the charging system, it may be overcharging. If it's not..... replace the battery. If you must use something, grease works. So does the battery terminal protector sold in aerosol cans at part stores. I keep some from Napa around if I need to use some.
Old 08-30-2015, 12:07 AM
Shrewcub's Avatar
That is my POV. Most batteries I have bought recently tho, leak. No overcharging, just pos batteries! I don't buy the junk ones either. Maybe I should.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 08-30-2015, 12:21 AM
Yeah, I hear you. I don't buy el-cheapo ones ether and some still leak. Batteries just aren't made well anymore. That said, I get several years out of them anyway! Just replaced one in the 1811 about 2 or 3 years ago..... it was at least 4 maybe 5 years old. Not bad for an L/G battery!
Old 08-30-2015, 11:23 AM
I have a deka battery in my 108, it was in the tractor when I bought it 4yrs ago so I have no idea how old it really is but its still going strong and starts my tractor no problem even in the dead of winter. When it finally dies I will have no problem spending the extra money to get another one.
Old 08-30-2015, 03:27 PM
cubby102's Avatar
cubby102 cubby102 is offline
Always just used wheel bearing grease...dad used it before me so I just picked up on it. I usualy clean the batterys up while cleaning the tractor though
