Old 09-07-2015, 08:07 PM
Jibber's Avatar
Jibber Jibber is offline
Originally Posted by timbo2 View Post
I think that black bracket is for the later rockshafts and you won't need it.
Ok. Just wanted to make sure. I am hoping the lift rod is long enough. haven't tried to mount it yet.
Old 09-07-2015, 08:19 PM
Is your tractor an early 2182 or a later 2182? From the pic you posted it looks like a late 2182. They made a rock shaft change partway through the production. The late machines use the black part the early machines did not but if I recall correctly you may need a brace of some sort to reinforce the rockshaft if you have an early machine.
Old 09-07-2015, 08:28 PM
Jibber's Avatar
Its an earlier model. Tell me more about this brace you are talking about. Need to know if anyone knows. My tractor is a very low hour machine so hopefully it will work the way it is for a very long time.
Old 09-07-2015, 08:44 PM
It's a link that connects that connects W to S. Item R in this pic. It was originally designed for the Haban snow plows. It reduces the likelihood of breaking the weld on the rock shaft and trust me you do not want to have to replace a rockshaft.
Old 09-07-2015, 09:23 PM
Jibber's Avatar
Hhhmmmm. Thanks for the detailed diagram. Just looked at my tractor and am now brainstorming how to brace W to S. Shouldn't be too hard to get a piece made. I can see how it makes sense to brace them together. The snowblower is very heavy. I wonder if Extreme makes this part? Would be a good one to make and sell! Hint hint!!
Old 09-07-2015, 09:58 PM
timbo2's Avatar
timbo2 timbo2 is offline
I tore up my rockshaft that way with a Haban plow, it was before I knew what that cross shaft support brace was for. Huge regret on that one.
- Tim
Old 09-07-2015, 10:12 PM
timbo2's Avatar
It'S #43 in this diagram.
http://www.partstree.com/parts/cub-c...pivot-control/
- Tim
Old 09-08-2015, 07:05 AM
Jibber's Avatar
Thanks Tim! I see that it is unavailable now. Anyone know where I can get this part?
Old 09-08-2015, 10:37 AM
ivel03 ivel03 is offline
If you have one can you take pics and post with dimensions? I asked a while back but no one responded with dimension-ed pics: http://www.onlycubcadets.net/forum/s...13&postcount=2
Old 09-08-2015, 11:23 AM
timbo2's Avatar
I'll get some later but hopefully some of the guys on here that are good with metal can whoop up a few for sale.
I'll offer mine as an original if needed as long as I get it back.
- Tim
