Old 07-24-2015, 08:29 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
they handle so much nicer set up like that
Old 07-24-2015, 08:56 PM
austin8214's Avatar
It has definitely helped my kids.
Old 08-17-2015, 12:08 AM
bschmittling bschmittling is offline
Originally Posted by dvogtvpe View Post
you don't want to watch tires. you want to sit square in the seat. if you lean back, lean straight back unless 1 tire is an issue. most people when they lean back tend to transfer weight to the arm they are holding on with.
We had a test-n-tune at a new track last week. Made about 6 pulls. The sled was set up to let you pull over 100 feet. Planted my but firmly in the seat, leaned back as far as I could and kept both hands on the steering wheel to avoid shifting my weight to one side or the other. I could tell a difference. The tractor tracked mostly straight. When it didn't, I could lean to one side or the other to straighten it out. The track was a hard track so no digging holes this time. It was a good day.
Tried different tires. The 23" super lugs did great and pulled 157 feet. The AT101s also did good at 159 feet. My 26" tires didn't do well, 134 feet. I don't have the gears to run them properly.
Our club lost it insurance and had to cancel the last pull. Hoping they straighten it out before the trophy pull in October.
Old 08-25-2015, 01:32 PM
Here is a pic of the offending tire watching habit. You can see the gravel texture of the track.
File Type: jpg 11214067_915882441813484_3888947527146802905_n[1].jpg (29.2 KB, 152 views)
Old 08-25-2015, 07:56 PM
dvogtvpe's Avatar
your supposed to be looking down track to where you want to go, you don't want to hit ruts from someone else. I usually have my run planned before I ever hook to the sled. unless some one takes the line I want to run . I pick an object at the end of the track or keep track of how far off the side line I want to be. I might watch a tire on the starting line as I slip the clutch but even that's is pretty rare. you don't get to where you want to be not looking where you're going
Old 09-09-2015, 12:56 PM
CumminSHO's Avatar
CumminSHO CumminSHO is offline
Do you have fluid in your tires or just the rear weight in the back?
1965 IH Cub cadet 102
Brinly 10" plow
42" deck
Front mount snow blower
Front Mount Push Blade
Red Spring Aluminium clutch
Old 09-09-2015, 04:46 PM
I have 70 lbs. of weight in the back. No fluid.
We had a club meeting last night. They found some insurance we can live with.
Thinking about changing the head on my tractor. Would it be better to run an LP head, or one with the heart shaped combustion chamber milled 0.05? As far as I know, every thing in the K301 is stock.
Old 09-09-2015, 08:06 PM
dvogtvpe's Avatar
its hard to beat an LP head
Old 09-09-2015, 10:26 PM
Will I have problems starting the engine with a starter/generator because of the extra compression?
Old 09-10-2015, 03:41 PM
austin8214's Avatar
It shouldn't be a problem. Just make sure your S/G has top notch bearings in it.
