Old 07-12-2010, 02:15 PM
Ash_129 Ash_129 is offline
Default Question about front deck hangers. 38"-48" "triangle shaped" decks.
I have a question regarding the front deck hangers on the 48" triangular shaped deck.
I picked up a 48" deck from a fellow about a month ago (the ID tag is missing, but is for sure a 48"). It came with everything but the front hangers. Are there different front hangers per size of deck for these series of decks? These are the late 60's to early 70's style with non-cast iron ends, but cast iron front nose section.
Currently I'm borrowing the front hangers off of my 38" deck. They seem to fit OK, I suppose. But, I'd like to pick up another set, or the proper ones if that's the case.
Thanks for any help.
Old 07-12-2010, 03:24 PM
FFGino FFGino is offline
Default Older deck question
The 38" and 42" decks use the same nose piece but the 48" is different. I purchased a 48" off of ebay and when I received it, it wouldn't bolt up. The shipping was going to be more than I paid for the part, so into my parts bin it went. My problem was that the bolt holes on the front side weren't wide enough to bolt on. Maybe someone else has had a better experience with this and will chime in soon.
FFGino, Happy Cubbing!
Old 07-12-2010, 04:35 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
one thing i do know is that parts for the 38 and the 42 do interchange from the nose piece to the hangers and the spindles, i was told that parts for the 48 only fit the 48
Old 07-12-2010, 04:47 PM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT IROCKWITHDIRT is offline
My understanding is that the 38" and 42" use one muel drive, and 44" up decks use another.
Old 07-12-2010, 05:55 PM
I'm sorry guys, I probably should have been a little more clear. It is not the cast iron nose piece that I'm referring to, but the front clevis.
Old 07-12-2010, 06:27 PM
To the best of my knowledge there are two different styles of clevis (for that time period of deck) they look different but I believe they measure the same.
Old 07-12-2010, 09:47 PM
I have a 42" on the 149 and a 48" on the 169 and both have the same clevis.
Old 07-12-2010, 11:41 PM
CMA's129's Avatar
CMA's129 CMA's129 is offline
I have a 42" Two 44"s and a 50" and they are all the same. I have a couple sets of extras too if you would like to try em!
"Good Dogs Never Live Long Enough!" Casey Angeletti
Old 07-13-2010, 08:32 AM
Thanks for all of information everyone. I believe that you have answered my question.
Cheers.
