Old 10-03-2015, 06:52 PM
BooBoo BooBoo is offline
Default Ultrasonic Cleaning Fluid--What Kind??
I was reading a thread about using a ultrasonic cleaner to clear carbs and small parts.Do these units use different fluids depending on what your cleaning.If most of what i want to clean will be small engine parts,is there a type of fluid i should use.If so what is the name and where can it be purchased.Thank you
Old 10-03-2015, 07:12 PM
Water and simple green seems to be pretty popular from what i've read.
Old 10-04-2015, 08:30 PM
yeeter yeeter is offline
I have some water based degreaser from harbor freight when I picked ip a parts washer. It would work well in an ultrasonic bath as well
Any water based degreaser/ cleaner fluid would be my choice (solvents would work, and would even cavitate at lower pressures, but I would stick to water based cleaners)
Old 10-05-2015, 06:14 AM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
I have had my ultra sonic cleaner for 2 years and love it.
If a part is greasy I use tide laundry soap.
For others including carbs I use dawn dish soap.
Heat is important.
