Old 10-25-2015, 11:24 PM
Congrats on the fix Tim Nice to turn a negative into a positive and relatively easy... and cheap
Old 10-25-2015, 11:49 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Good deal Tim!
Just keep that white stuff north of the Mason-Dixon Line!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-26-2015, 11:09 AM
Originally Posted by jaynjeep View Post
Great tip on the hour meter!
I sprayed it down in with a straw and put a pretty good amount in and let it sit for a few minutes, once I hooked the battery up and it started working I flipped it over to drain the extra fluid out and put it back together. Hopefully it keeps working but if not it will get replaced by an oil pressure guage.
Old 11-14-2015, 04:49 PM
i finally got some free time to work on the 1811, the hour meter repair didnt last and it stopped working again so i replaced it with an oil pressure gauge and was happy to see that it carries 55lbs at an idle and about 65lbs at wot when warmed up. the po must have had some extra lighting and had a ton of extra wires running all over the place so once i got it all sorted out i have working lights except for one headlight thats burned out. the cat 0 lift went on easy enough and tomorrow i will make lift links so it will be complete, i also tubed the front tires. also on the list for tomorrow is to mount the snow plow and bolt on the winter tires that are already loaded and have the chains on. i had a fun day working on it and it was really nice to take it for the first ride all in one peice.
Old 11-14-2015, 05:56 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
That first ride is always great isn't it?!
Jay
Proud owner of the following:
Old 11-14-2015, 06:39 PM
Thats gonna look nice when you paint it.
Up to 534 and counting...
Old 11-14-2015, 06:51 PM
Hopefully you get to see it in person next year at PA plow days.
Old 11-14-2015, 09:34 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Sounds like a fun time!! Cub stuff is fun!
1- 1200 in pieces
1- 1864 in pieces
Old 11-14-2015, 09:44 PM
Terry C's Avatar
Terry C Terry C is offline
Hurry up cause I want to see what a new one looked like. Well with you doing the work it probably will look better that it did new
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-14-2015, 09:51 PM
believe me i want to tear it apart right now and get painting it but i figure its best to run it for the winter to work any bugs out before i make it pretty.
