Old 10-28-2015, 02:42 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default K series block...
I was wondering if anyone has resurfaced a series block themselves.? I wasn't planning to build this engine but I ended up looking into it and found that it was in good shape inside. The piston and rod were shot from overheating, I assume from low oil and the #30 carb on it. I already have the parts that were ordered for another engine that has an egg cylinder. I've found with this new engine that the cylinder deck isn't flat. I know that the head will clear this rise but I'd like to flatten the deck. The local machine shop quoted me $225 to surface it. I really don't think I want to spend that on just surfacing the block. So has anyone done this at home with just the basic tools? If so how and what did you do and use?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 10-28-2015, 04:24 PM
j4c11's Avatar
j4c11 j4c11 is offline
Why would the #30 carb cause overheating? I thought that was the carb it's supposed to have, I have a #30 on my K321
Old 10-28-2015, 10:48 PM
Really, $225 to surface it?
I resurfaced the top of my K301 block at work during my lunch time ( 30 minutes ) I even had time to eat my sandwich
I need to get a Bridgeport mill.
Old 10-28-2015, 11:35 PM
Terry C's Avatar
Terry C Terry C is offline
Thats a ridiculous amount.
Like Jeff said it doesn't take long.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-29-2015, 12:36 AM
I do agree that $225.00 is a lot of money for a half hour job. Maybe that shop is geared more toward a different type of work, or they have enough business in the kind of work that they normally do, that setting up and then doing the job is (and I mean this in the kindest sense) more trouble for them than it is really worth.
Just because one shop wants a ton of money to do the work doesn't mean that another shop wouldn't gladly take the job for a more reasonable price. I'd try shopping around a little.
On the other side of the coin... Even IF you already have a suitable existing building, go buy your own vertical mill, get a good 3 phase converter, get everything wired, buy a DRO, 3 power feeds, a vice, an indexing fixture, a chuck, then start buying tooling and set up equipment. THEN make your money back.
Luckily, you can get your lathe set up and running for about half the cost of the mill and related items.
Old 10-29-2015, 08:06 PM
Send it to Jeff in PA along with a sandwich he might do it for you.
Old 10-29-2015, 08:33 PM
bocephus1991's Avatar
Unless your experienced and have the tools I'd have a machine shop do it. I'd shop around a get some price quotes. Or you could send it to Jeff!
Brian
Old 10-29-2015, 09:06 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
With a half decent milling machine that job shouldn't be too bad.. I'd shop around a bit... I have a friend that loves to play with his mill.. He would probably do it for free just to have a project! too bad you aren't closer to me.
I wouldn't attempt it without the proper tools or machinery..
Good luck!
Jay
Proud owner of the following:
Old 10-29-2015, 09:10 PM
Easy to set up and fly cut on a Bridgeport.
I'd look for another shop near you.
Old 10-30-2015, 02:41 AM
EarlJ's Avatar
The k301 uses the #26, I really dont know what caused it to run hot. It was like that when I got it..
