I just got my headlights hooked up (been off since I got the tractor). Now, when the tractor is running and I turn the lights on it blows the main fuse and tractor dies ( I assume fuel solenoid loses power). If the tractor isn't running and turn the lights on everything is OK . where would you guys look first or has anybody else had the same problem? Thanks.
I'd be checking the headlight circuit.....
Agreed. The last Cub my Pappaw bought (1863) blows fuses. I haven't had the time to find the short, but did pull the blue wire from the ignition switch and my uncle that abuses it hasn't told me it blew one since. I would like to get it over here this winter and find it while doing a good cleaning ect.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
I did notice when the engine was running and i switched the lights on the volt light came on but was dim and lights never flashed and then the engine died. Maybe that helps
Make sure the key switch is in good shape and what not. I had this happen on a 2284, turned out the connector on the back of the switch went all fun house mirror on me. Cleaned the connections and crimped a few new ends on the wiring harness. Hasn't done it since
My 1862 blew a fuse every time I turned on the lights. Turned out that the headlight bulb was broken and the element was shorting out against metal housing.
