Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 11-11-2015, 08:21 AM
samckitt samckitt is offline
Default Repower for 682
My Kohler went kaput last weekend and looking to replace the engine. I have looked at Smallenginewarehouse.com & they no longer have a Honda kit for it, they told me the Hondas run hot & Honda doesn't make stuff for this kit any longer, and all they have is the Vangaurd series from Briggs & Stratton. I have thought about finding a Kohler Command & make it work, and have thought about the B&S kit to replace. Opinions....?
Also while I'm at it, why not give it a little more HP, SEW has B&G kits for other Cub Cadets in 23 hp versions, will they work in the 682? These for example says it is for a Cub Cadet 1811, 1812, 1860, 1861, 1862, 1872, 1882:
http://www.smallenginewarehouse.com/...tegory=1709590
Are they the same as the 682 only more power? Looks like the shaft is different though.
I have been reading posts here about engine swaps, just looking for some more opinions.
Thanks
Scot
Old 11-11-2015, 08:36 AM
The bigger engine will work. The other listed tractors are the same style.
Old 11-11-2015, 09:00 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Harbor freight has a Honda clone. It can be made to work, if you can do a little fabricating.
http://www.harborfreight.com/engines...epa-61614.html
Old 11-11-2015, 09:08 AM
Am I being silly now, 28hp fuel injected Kohler...... (insert Tim allen grunt here)
http://www.smallenginewarehouse.com/CH745-0113-TO.html
Old 11-11-2015, 09:15 AM
More power is only silly if you:
-can't afford it
-are a sissy girl
Old 11-11-2015, 09:19 AM
It goes along with pretty much every car I have ever owned. I have converted 3 of them to fuel injection & more power. Current project, 1986 Monte Carlo SS, stock has 180 hp carbed 305 5.0L, converting it to a 450ish HP 6.0L LS2.
Old 11-11-2015, 11:52 AM
ford4150's Avatar
ford4150 ford4150 is offline
I put a 20HP Vanguard in my 782. Easy swap.
Old 11-11-2015, 04:17 PM
Just my 2 cents but I think your just wasting your $$$ putting 28 HP in a 682. The Hydro can't use it nor can your mower deck. The 18HP SEW kit for the 682/782 is more than enough. That said it's your tractor and your $$$$.
Old 11-11-2015, 05:10 PM
jimbob200521's Avatar
Yeah but just like a racing stripe, it'll make the tractor faster?
-Ryan
Old 11-11-2015, 05:58 PM
Yeah..................
