			Guys ,  wondering how to get more lift height on my 1812 with 450 blower,  it just barely lifts it off the ground  wondering if I over looked something
			Can you take  a picture of the blower in full up position??
	102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670.  |
			Lift rod unscrews to get more lift.  None of them lift very high.  I have mine all the way out and maybe get 2".  Best option:  remake lift rod longer.
	PS: Your belt isn't on.... ![]() ![]()
			mine might lift 1/4 or so
 Jon, on Dads 451 we can get 4 to 5 inches of lift in full up but my 551 can only get 3 inches at best but we are dealing with supers not GT's???
			Belt I know,       I am in the installing process,  belt comes later
			I have a 451 which is very similar to yours. One of the differences I see is that the Vertical lift link on mine has three holes in it vs. one on yours. (284-5412 in your photo)
	Item #22 shown here http://www.partstree.com/parts/cub-c...ivot-assembly/ I have mine in the top hole and get plenty of lift with it. You may need to drill a couple holes in yours above the one you are currently using. This may have been an improvement made in the 451?? Good luck, Ike  |
 ![]() Otherwise.... I dunno. Maybe they have a different lift rod? Quote:
 Drilling holes is an option, but make sure you don't go too far. Then it won't lower enough. I noticed on the second look at the pics that the lift link in question is (I think) on the wrong side on the lower tube. I believe it goes on the inside.... but I'm at work and can't look at one to be sure. Simplest solution is making the lift rod longer. I doubt it's unscrewed far enough. At least try that first.
			J-Mech
	my lift rod is out as far as it will go , link I will have my machine shop make me one unless you know of one of our guys that will make a longer one ? thnx Rob  |
